You could use some bracket that fits in the cracks (right word?) between the dashboard and air-vents.
Then mount your screen on some swivel-thingy...
The radio seems awfully fit to be replaced by an indash install of a xenarc/lilliput though...
Joa
Anyone have any idea how I can mount a screen here without having to do any major modifications? because I have no idea how to do any kind of fabricating...
Joa
Where do I find those?Originally Posted by JC-S60
Well, that would be nice... but I don't want to cut anything and I can't fabricate. Unless I could find another dash to cut up, I don't want to cut anything.Originally Posted by JC-S60
Not sure you'd need to cut the dash, cut some flat textured plastic sheet to the same size as the front of your stock stereo and cut a hole in that for the screen. Mount the flat panel in the opening vacated by the stereo so that it is flush with the back of the dash trim & you're done.
Not easy, but you could put a screen in there without cutting the dash trim. You just have to lose (or move the stereo).
I'm sure someone who has done this will chime in. I have as yet to do it myself.
If removing the stereo & fabricating mounts doesn't appeal then the alternative is to use a flat metal mounting plate that fits between panels/vents. They are usualy used for mobile phone mounts but can double up as a screen mount. A quick google search turns up this: http://buy-car-electronics.efastmall.com/ZZ23407.html
To this you'd fix your stock screen mount or something that swivels from Ram mounts: http://www.ram-mount.com.
The latter alternative is what I'm thinking of for my Corvette.
Wouldn't I lose the buttons then? What the hell are those things for, anyway?Originally Posted by pip
Move the stereo? Where else is there to put a double-din head unit?Originally Posted by pip
Sweet another 2nd Gen Altima owner. I've been lurking for a while but this is my first time posting.
Here's what I did to mount a screen. First I bought this LCD screen.
Heh those are some happy old people.
It's selling for $114 now I think I picked it up for $80-90. It's not a great screen but it's fine aslong as you don't have any small text.
Next I took out the pocket(21) from the Altima's dash(20). It's the thing below the radio with the ash tray and cig lighter in it. And from behind I mounted a bit of plexiglass with the screen screwed into it.
So you can see the screen where the pocket would be. It's not touch screen so I just use an IR remote. I wish I could snap a picture but unfortunately I don't have my camera with me.
and that's not too low? I was worried that it would be too low in the radio spot...
Where did you put the actual computer?
It's fine for me. Avoids a lot of glare by being down there too.
That isn't too low? I was afraid that it might be too low in the radio slot. Also, where did you put the computer?
I put the computer underneath the passenger seat. It's a mini-itx board in a generic enclosure. It's snug but it fits.
