Results 11 to 20 of 23
Thread: Repairing Lilliput touch controller / Fried Zener
  1. #11
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by digitalww
    I can probably take this component from one of the bad controllers I have and send it to you, for a $1
    What do you think?
    Armen
    Sounds great. Where should I send the $1? PM me with the info.
    Thanks!
  2. #12
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by rando
    ... Maybe that 5V isn't the label for the pin in which case this zener may actually NOT be foward biased (a good thing). I guess I better double check this when I get home. It was like 1AM when I looked at it. argh.....
    OK, that was it. Who would have guess that the red wire was ground and the black wire was 5v. Apparently the 5v did refer to the zener and thus it was reverse biased ... the planets are aligned again.
    Armens replacement zener came in today, it's installed, and my touch controller is safely working again. BTW, the markings CJ5.1 appeared on the part and I conrfirmed it to regulate around 5V.
    Thanks to each of you that helped and a special thank you to Armen for providing the replacement part.
  3. #13
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Thumbs up
    Thats good news rando. Kudos to Armen for providing his help
    Cheers
  4. #14
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Well, this is what it looks like when it's shorted from over voltage.
  5. #15
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    I fried my Lilliput touch controller. Looking at it, there is a diode across the +5v rail and ground that got fried. When i removed the diode, the controller worked again. Accoring to the board silk screen, it's a foward biased zener. I'm not sure I understand what that zener would be doing there. If forward biased, would that essentially short the USB +5v rail?
    In any case, does anyone know what it is? I assume it was 5.1v zener (reverse biased despite the what the silk screen says) there to protect against an overvoltage. This is supported by the theory that my t/s controller started working again once I removed the fried part.
    Rando,
    My controller died too. Looked at it and there was some indication of the over voltage (compared to the other pictures in this post). I removed the zener and mine still doesn't work. I saw the one side was 5v rail and other was ground. did you just leave the zener off and it worked again, or did you put something in its place until the replacement from Armen got there?
    Batman
    Batman@TheNewBatcave.com
    AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
    www.samshomepage.net
    www.Cars-N-Computers.com
  6. #16
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Batmanatthenewb
    Rando,
    Batman
    Once I removed it, the touch kit worked again (albeit unprotected from any kind of power issue). I assume this means the zener fried into a short, or at least a near short. It crumbled into pieces as I unsoldered it. The replacement part was important to restore the limited over / reverse voltage protection.
    If your controller isn't working without the zener then I assume you have other issues. It's fairly lucky (in my case) that the zener burned to a short. Once it burns to an open, you'll no longer have any protection and your ICs are next in line to get fried. Check the data sheets on some of those components. They are fairly clear that they cannot survive even momentary spikes beyond 5.5V.
    In other words, the zener provides only limited protection and eventually the controller will be killed by errant input voltages.
  7. #17
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Curiosity
    Yep, though mine was much blacker than that. It scorched the circuit board and even melted the solder joints.
  8. #18
    Jul 2004
    Norway, Bergen
    Who or what is armen?
  9. #19
    Mar 2004
    Vancouver, BC, Canada
    Got to love the Lilliput controller boards with red for negative and black for positive.
    I fried my controller because I assumed they followed standards.
  10. #20
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by superdude
    It might help if you actually read the thread before you post.
    What do you think?
    Armen
    As you can see, Armen is DigitalWW. DigitalWW is Armen. I think that about clears it up.
  1. Replies: 20
    Last Post: 07-23-2004, 10:26 PM
  2. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
  3. GROUP BUY: Lilliput TM-701VGT LCD
    By krystar in forum Classified Archive
    Last Post: 01-16-2004, 07:31 PM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. WTB: 10.4" touch screen overlay & controller
    By Cordell in forum Classified Archive
    Last Post: 08-06-2003, 08:15 PM
