Results 1 to 10 of 12
Thread: Lilliput and xp embedded
    Constant Bitrate mikevsgeek's Avatar
    Jul 2004
    Auburn Maine
    I've been playing around with xp embedded the past couple of days, trying to get the lilliput touchscreen to work (it works perfectly in xp pro so I know the screen isnt defective)... I've componentized all the drivers for it and they build into the runtime image without any errors, device manager sees it fine... but when I install the software, it wont see the device, and the touchscreen doesnt actually work....
    anyone get it working with xp embedded?
    Constant Bitrate jaeger's Avatar
    Jul 2004
    Galveston Is., TX
    really stupid question - i downloaded the xp embedded, and i am not sure how i can build and modify it. i know [i think] i need the tools suite...but that's 995$, and uh...i don't see how that will benefit me. I am very sure I am missing something [as in forgetting]. how did you create your build?
    plus, i think you'd be really lucky if you had gork or kai445 [or something like that] look at this thread
    nine.
    Jul 2004
    Auburn Maine
    Quote Originally Posted by jaeger
    there is an abundance of information about xp embedded thruoght microsofts website.. they have how-tos to do just about everything, and how to fix a majority of errors that you might get...
    basically what you have to do (quick run thru):
    1) use tap.exe or ta.exe to get a hardware snapshot of the computer
    2) import the .pmq file into the target designer (which will automatically put in a majority of the software/hardware components you will need)
    3) do a dependency check and fix all of those & remove unwanted/unneeded components
    4)change any of the settings that you would need to change
    5) build the run-time image
    6) deploy it
    took me saturday of last weekend to get the jist of it, and now im changing and deploying the image from my workstation to the jeep-puter in about 15-20 minutes (depends if it has my full attention)
    what im stuck on right now is getting the touchscreen to work tho , everything else is working great (so far)
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    I installed a lite version of XP without a mouse connected and the touchscreen wouldn't work!
    Jul 2004
    Auburn Maine
    Quote Originally Posted by Laidback
    mouse is working... keyboard works, everything works except the touchscreen, but it works in xp pro...
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Is the embedded recognizing the USB 2.0??? Perhaps if the USB is ignored, the touchscreen will be malfed
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Jul 2004
    Auburn Maine
    its just usb 1.0.... should be getting picked up? imma have to look into that tho!
    Newbie Deos's Avatar
    Lightbulb
    Quote Originally Posted by choyak
    Vehicle: 2004 Toyota 4Runner SR5
    Posts: 86 Is the embedded recognizing the USB 2.0??? Perhaps if the USB is ignored, the touchscreen will be malfed
    Epia MII-12000; Hitachi Travelstar 60GB; Holux GPS mouse with iGuidance 2.0; Lilliput 7" touchscreen; Magicstor compact flash 2.2GB hard drive. Netgear WG121 USB WiFi
    Yo m8
    a question out of topic...
    Your signature states Epia MII-12000; Hitachi Travelstar 60GB; Holux GPS mouse with iGuidance 2.0..
    but aint iGuidance only made for PocketPC platforms ?
    in this case how did you get it to work on an epia board ?
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    What are the benefits of WinXP embedded??
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    350MB XP installation footprint... (minimum that is)
  1. Lilliput Drivers for XP
    By Showmehow in forum Newbie
    Last Post: 07-21-2004, 11:18 AM
  2. Lilliput & Win XP pro !!!! problem
    By vicky_obee in forum LCD/Display
    Last Post: 07-05-2004, 10:12 PM
  3. Lilliput not working v1 & v2
    By darthvinh in forum LCD/Display
    Last Post: 05-08-2004, 04:37 AM
  4. Lilliput 619GL-70NP Touchkit XP Home Install
    By Windchsr in forum LCD/Display
    Last Post: 04-25-2004, 08:23 AM
  5. Replies: 2
    Last Post: 12-18-2003, 09:18 AM
