Results 1 to 5 of 5
Thread: TM700TS problem!!
    May 2004
    Northridge CA
    TM700TS problem!!
    i have this monitor
    http://www.digitalww.com/TM700TS.htm
    it worked fine until last night.
    the backlight stays on whenver theres power to the 12v connection
    and when i turn it on it will work fora bout 30 seconds then go back to the white screen which is bacisally just the backlight with the screen off.
    it will flicker and have wavy lines moving across the screen.
    it seems very random
    sometimes it will work fine for a long time but it will always have the backlight lit up even when i turn off the monitor.
    this happens wheter or not something is plugged into the monitor.
    anyone know whats wrong?
    the thing is that it is molded into my dash so i cant return this for exchange.
    but its been working fine since june
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Check the ribbon cable between the LCD panel and the controller. It sounds like it is damaged or not making good contact.
    Armen
    Quote Originally Posted by dannn
    i have this monitor
    May 2004
    Northridge CA
    sweet ok.
    i think im gonna check the fuse too.
    May 2004
    Northridge CA
    is this the cable?
    http://www.digitalww.com/ribbon_cable.htm
    thanks a lot for the help!
    May 2004
    Northridge CA
    i examined the cable and it is fine.
    i tried unplugging the ribbon and the backlight stayed on
  1. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
  2. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  3. power on problem ??? help please anyone
    By Pingo1969 in forum Power Supplies
    Last Post: 04-07-2004, 08:47 AM
  4. psone screen video problem
    By WILD9 in forum ME Archive
    Last Post: 11-27-2003, 01:38 AM
  5. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 09:19 PM
