Results 1 to 10 of 11
Thread: Lilliput XGA Composite Inputs..HELP!
    DLe
    DLe is offline
    Constant Bitrate DLe's Avatar
    Mar 2004
    Hey everyone. I just purchased a Lilliput XGA touchscreen and am having problems with the composite inputs. I thought that it would simply be plug-n-play, however I spent probably about an hour messing around with the settings without any success.
    VGA works perfectly and I can hear sound when I'm in composite video mode, I just simply can't see any image! "No Video" just displays on the screen. I've tried to push my USB plug in all the way and it still doesn't work. I tried to get the inputs to switch using the OSD menu and it appears that "s connector" is VIDEO 1 (however I don't have any s-video inputs). Is this odd or is it just me?
    Please help me out. The reason why I bought a lilliput was because it was cheap and had 2 video inputs. Rahh!
    Jan 2003
    Ruston, LA
    First off, plug something else into it to see whether it's your monitor having problems
    or the sending device.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    DLe
    DLe is offline
    Mar 2004
    I have! I tried many different inputs. (Camera, Playstation, VCR) So far, VGA only works perfectly...I can't see any image on composite . HELP Please...im so sad right now. (just got the monitor 2 days ago and i'm already sad.)
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    It's safe to assume you hit the video source button to select VIDEO1 or 2, right?
    DLe
    DLe is offline
    Mar 2004
    Yes, it's safe. I've tried on the remote and on the screen itself. PC/AV still just "No Video".
    There shouldn't be any settings that I need configure before seeing composite video right? No NTSC settings or anything like that right? Well, even if that was the case, I played around with most of them. I can't believe this, is there something wrong with my new monitor!? If true, then
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    Make sure that your RCA video in is plugged into the YELLOW plug of the wierd fake usb connector and not the RED or WHITE ones? I got mine to work simply but plugging it in, turning it on and pressing the source button...
    Jul 2004
    could ba a bad cable, mine wouldnt do vga until I resoldered a bad conn
    DLe
    DLe is offline
    Mar 2004
    Quote Originally Posted by chargin
    Turns out that it was a bad cable. The guy that I bought it from said that Lilliput's cables had a 4% chance of being defective. I had to return the cable back to him today so I could get a new one. I hope he's right. Those bastards!
    FLAC ppgt94's Avatar
    May 2001
    USA
    Make sure it's a TSV model. The TS model doesn't have active composite inputs.
    DLe
    DLe is offline
    Mar 2004
    Quote Originally Posted by ppgt94
    Haha, not to make you look like you didn't read ppgt94, but as stated in the header, this is a Lilliput, not Xenarc..
    thanks anyways though.
  1. WTB: Lilliput 7" XGA Touchscreen
    By DLe in forum Classified Archive
    Last Post: 08-12-2004, 04:22 PM
  2. HOW many INPUTS? LILLIPUT.
    By ericdee in forum LCD/Display
    Last Post: 04-24-2004, 02:09 PM
  3. Lilliput composite input flashing?
    By Misanthro in forum LCD/Display
    Last Post: 12-09-2003, 04:58 PM
  4. Lilliput +cheap +composite
    By eminence in forum LCD/Display
    Last Post: 10-31-2003, 03:52 PM
