Results 1 to 7 of 7
Thread: Lilliput overrange through BIOS then fine?
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Question Lilliput overrange through BIOS then fine?
    Is this normal?
    I set the BIOS res to 800*600 and the type to LCD, now I get 'Overrange' through the post until XP starts up, then I get an image.
    I guess it works, but if I ever need to get into the BIOS, I'll need to pull the MB battery to reset it.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Feb 2004
    Florida
    Evening bump
    '02 GTI
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    I get the same thing only it usually happens between the BIOS and the XP login screen. Ocassionally it occurs all the way through the BIOS until the login screen. I've tried pretty much every BIOS settings with no apparent impact.
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    same here, i get the over range screen usually when switching from bios to xp boot.
    I also get the overrage screen in windows when i change resolutions quickly. like when i try a resolution and then revert to the previous one in a matter of seconds.
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
    Jul 2004
    Doing better than me...
    I dont even get an image until I get into XP. Before that, it's a Jurrasic Park image (I dont know why) with some white fuzzy stuff...
    Constant Bitrate JayKaye's Avatar
    Jan 2004
    Sydney, Australia
    try setting the BIOS to CRT + LCD and the other setting to PAL. Thats what I got and it works fine. (800 * 600)
    Car PC v1 - 1999 - 2000
    DOS 6.22 - MPXF - 2x16 LCD - 6.4GB
    Car PC v2 - 2002 - 2006
    XP - 7" wide/touch - GPS - Tank batt relay - 100GB
    Car PC v3 - 2008
    XP - 7" wide/touch - GPS - 802.11g - FM/XM - OBDII - WWW
    [||||||||||||||----] 80% complete
    Oct 2005
    Merseyside (BEATLES) UK England
    i can not reinsall the OS in the car, as my lilyput 8inch ts says overrange.
    untill windows is on properly, annoying
  1. hmm...just fried the "egg" for my lilliput
    By delussional77 in forum General Hardware Discussion
    Last Post: 11-25-2004, 01:50 AM
  2. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
  3. FS: Parting out Lilliput
    By 047025n in forum Classified Archive
    Last Post: 06-26-2004, 08:52 PM
  4. Replies: 2
    Last Post: 06-20-2004, 12:10 AM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
