Results 1 to 7 of 7
Thread: 8" Liliput - VGA output stopped
    eor
    eor is offline
    Newbie eor's Avatar
    Mar 2004
    United Kingdom
    I've had my 8" Lilliput with touch screen several months, and its worked fine.
    However recently the display on VGA was very dim and slightly off colour, then the next time I used it, nothing!
    As soon as I set the laptop to external monitor the Lilliput flashes up the 'No VGA signal' message so something is getting through. I've tried the display using another laptop (thing the 1st laptop output had gone duff), still no display.
    The two video inputs for the cameras also attached still work fine. Not using the S video input.
    Can anyone give any leads please?
    Many thanks in advance.
    PS as a last resort I'll try sending it back under warrantee, but usually that’s expensive or the retailer (in Hong Kong) refuses to answer emails, therefore no warrantee.
    __________________________________________________ __
    Steve
    aka A very wild....wild camper
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Sounds like bad connection and/or loose pin on the monitor's connector.
    Can you test for continuity every pin with a multimeter?
    eor
    eor is offline
    Newbie eor's Avatar
    Mar 2004
    United Kingdom
    Quote Originally Posted by Seth
    I've already been down that road with no dodgy connections found.
    I'm reluctant to open the unit up as there is a seal on it, if broken it gives an excuse not to honour the warrantee
    Steve
    Jun 2004
    Athens Greece
    Maybe there is something wrong with your laptop. Did you try it in a different PC ?
    eor
    eor is offline
    Newbie eor's Avatar
    Mar 2004
    United Kingdom
    Quote Originally Posted by eor
    I've tried the display using another laptop (thinking the 1st laptop output had gone duff), still no display.
    As above, but when I can un-wire it from the van, I'll also try it on a PC, though I don't hold out much luck as the 2nd laptop didn't work
    Steve
    eor
    eor is offline
    Newbie eor's Avatar
    Mar 2004
    United Kingdom
    Just tried another monitor in the original laptop, so the vga output is okay
    Steve
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    good work
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
  1. Liliput 7" or 8" Touch Screen
    By bertie in forum Newbie
    Last Post: 03-24-2005, 10:13 AM
  2. Fuzzy output using long VGA cable...
    By sq_geek in forum LCD/Display
    Last Post: 06-11-2004, 08:37 AM
  3. using old Gateway Profile with no VGA output?
    By suprthug8d in forum LCD/Display
    Last Post: 06-01-2004, 12:19 PM
  4. 8" - 10" LCD w/ VGA
    By Bobby_Xterra in forum LCD/Display
    Last Post: 05-17-2002, 04:44 PM
  5. Wanted: VGA LCD between 6 - 8"
    By sm00ch in forum Classified Archive
    Last Post: 04-15-2002, 05:34 PM
