Results 1 to 7 of 7
Thread: M10000 VGA and Tv-Out Problem.... help
    Newbie Lazyboy62's Avatar
    Feb 2004
    Denmark
    I use a : 7" TFT/VGA and a second 7" TFT/Monitor, connected to my
    Motherboard :Via Epia M10000.
    And can't get both TFT running at the same time !! Why ??????????
    I have just updated my Bios, And selected it to run CRT+LCD
    I did also update the VGA driver and the S3 driver.
    In XP under System I chose both TFT to run at the same time !!
    But........When VGA run, S-vhs don't !
    And if S-vhs run, VGA don't.
    Also used a small program to identify the Grafik Chip ID : 3122
    But can't find any support on that !
    Hmmmmm...
    LazyBoy 62. Denmark
    Feb 2003
    SE, PA
    just throwing an idea out, I couldnt get my 6" monitor to work with my Epia M9000...
    ended up their wasnt enough internal resistance in the monitor for the Epia to see it. I had to solder a 75ohm resistor in the cable and it worked fine.
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
    Feb 2004
    Denmark
    resistant..... How ??
    How and where did you mount the resistance !
    Did you use the RCA or S-vhs port ??
    And do you have 2 TFT, (because of the resistance !!) ??
    Lazyboy
    Nov 1999
    Ishoej, Denmark
    i believe he's using rca, al the times i have heard about this problem its been on rca.
    However, i think your problem is different, since you can actually get signal on the screen(s-vhs). It sounds to me like its a driver/bios problem, even though you have upgraded both.
    Can you be more specific on when you have vga an not s-vhs and when you have s-vhs and not vga.
    I have the same setup as you (only one screen though) but i could run a test on my system, to see if i too have this problem.
    What happens when you use vga and rca ?
    Feb 2004
    Denmark
    Over Range....
    It's the same problem... When using RCA or S-Vhs....
    If I chose VGA and TV-Out, the VGA goes blank and a message turn up..
    "over range"
    Tainted Love Cris's Avatar
    Romania
    Have you got this working?
    Variable Bitrate 12Vsystems's Avatar
    Mar 2005
    Orange County, CA
    I have the same problem
    I am seeing the same problem using a lilliput 7" VGA and TV. As soon as the TV is turned on the VGA displays "over range"
    I have upgraded my bios, device driver and nothing has helped.
    Motherboard is a LV-602 with Prosavage PM133 Intergrated graphics running windows XP home.
    Spent all my money on carputers now I have to work a real job.
    http://www.858graphics.com
  1. VGA and TV out @ same time?
    By dannn in forum General Hardware Discussion
    Last Post: 06-13-2004, 01:06 AM
  2. vga to tv converter
    By corsamel in forum General Hardware Discussion
    Last Post: 11-13-2003, 02:43 PM
  3. FS. VGA to TV (composite and s-VHS) converters.
    By Casper in forum Classified Archive
    Last Post: 08-13-2002, 05:33 PM
  4. VGA to TV converters anyone?
    By Casper in forum LCD/Display
    Last Post: 08-12-2002, 07:03 PM
  5. Problem with Jaton video 77 w/ TV out
    By Dustin Haug in forum Software & Software Development
    Last Post: 04-21-2001, 08:58 AM
