Results 1 to 5 of 5
Thread: My Xenarc is BROKEN!! (i think)
    Sep 2003
    Question My Xenarc is BROKEN!! (i think)
    Well, im installing my PC in my car and that all works fine. I have a Xenarc 700TS and it was working flawlessly. I took it out of the case, and when i was ready to go install it, i tested it just to make sure it still worked. For some reason, the Portable Display screen comes up, then goes into standby mode after a few seconds as if there is no signal from the computer. I'm not sure what the problem could be! Any help is much appreciated! :-)
    Thanks,
    Michael
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Try reseating the ribbon cables and make sure they are plugged into the right place.
    It could not be broken unless you dropped or fryed it
    Low Bitrate MikeXP's Avatar
    Aug 2004
    New Zealand
    I don't know much about those displays but if the ribbon cables are the type which look like circuits glued onto a piece of over head transparency sheets then you may have broken the circuits as they are very fragile!
    [ MP3CarPC.com :: Digitize your in-car experience ]
    * what happened to my sig and avatar :confused: *
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Are you sure you haven't broke any of the VGA cables going to the screens mainbaord?
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Sep 2003
    Thanks for all the quick replies. I just looked really closely at the board, and the small board with the actual monitor connector on it looks like its fried! One of the lines is busted going from the monitor connector to the solder points. Any way I can fix it or get a new board? :-/
  1. Xenarc direct cause of audio noise- help!
    By shidarin in forum LCD/Display
    Last Post: 04-19-2008, 10:53 AM
  2. pre-built Xenarc carputers any good?
    By ayclens in forum General Hardware Discussion
    Last Post: 07-07-2004, 10:44 AM
  3. Xenarc 700TSV cable broken.
    By ripper in forum Input Devices
    Last Post: 04-25-2004, 06:03 AM
  4. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 07:38 AM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
