Results 1 to 10 of 13
Thread: showing mediacar ONLY on the second display
    May 2004
    hi guys/gals
    I am using a laptop in my carputer setup, and am using UltraMon to try to keep programs running on the right screen. I am using MediaCar and want it to display ONLY on my in-dash monitor, not the laptop's. So I am extending the desktop to the other monitor and trying to get MediaCar to run on that one every time I open it. I can move it there, but am having problems like menus opening up on the primary display, and when I close MediaCar and open it up again it goes back to the primary display. Can someone help me here? The in-dash monitor is connected to the VGA out of the laptop.
    thanks!
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Switch primary display?
    May 2004
    I tried that, but then everything else goes with it too... I just want to get that one program running on only that monitor (which is why I am trying to use UltraMon). Any other ideas?
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    In MediaCar setup, put the screen startup location at x,0 where x is the width of your laptop screen (for example on mine, i will open MediaCar at 1600,0 for it to be on the second monitor)
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I know ATI do a monitor display program, you can decided what programs you want opening on which screen.. I think its a generic program that will work on any videocard.. but dont quote me on that.. think its called hydravision or something hydra
    May 2004
    thanks for the input, guys... I will try both of these suggestions
    May 2004
    another thing... is there a way to make MediaCar the "default shell", kind of like the way MediaEngine has that option? thanks again!
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    It isn't recomended but i am sure you can. There is some registry change. Look it up on google
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Try Dual Monitor setup (not extended desktop etc..) Then put your in-dash display as your primary and the MC will start there!!
    Variable Bitrate RogerWilco's Avatar
    Aug 2004
    the problem is generaly that your videocard, cant ouput that much. If you get a newer/nicer one it'll work. Its the same thing with DVD playback.
    Try playing a dvd on your primary and secondary, most likely it will only show on the primary, and a black box on the secondary. If thats the case, then you need a newer/diff video card
  1. Free DVD player for MediaCar
    By igmt in forum MediaCar
    Last Post: 06-11-2004, 02:30 AM
  2. Need Help with MapPoint and MediaCar
    By screa_34 in forum MediaCar
    Last Post: 04-21-2004, 12:38 PM
  3. Any way to relocate my display card??
    By SlimJimmy in forum General Hardware Discussion
    Last Post: 03-22-2004, 10:14 PM
  4. Which LCD Display for MediaCar?
    By burner in forum MediaCar
    Last Post: 11-22-2003, 12:57 AM
  5. Choosing a Character display...
    By Kryten in forum LCD/Display
    Last Post: 10-16-2003, 11:43 PM
