Results 1 to 7 of 7
Thread: 4X40 LCD Diagram
    Aug 2004
    Central New York
    4X40 LCD Diagram
    on the diagram from http://skylab.org/~chugga/mpegbox/files/lcd.GIF
    What does the line coming off the 100 mean? The one that comes off the center pin and goes to the bottom pin.
    Jul 2004
    Denmark
    It's a 100 Ohm pot ;-)
    Car PC: Via Epia M10000N ~ Morex Cubid 2699 ~ M2-ATX PSU ~ 512 MB DDR Kingston ~ G-Sat BU-303 GPS mouse ~ 80 GB Samsung 3.5" hdd ~ Ruwido Wireless IR Keyboard w/mouse keys. ~ 7" - MM400 Touch Screen
    www.autopc.dk
    Aug 2004
    Central New York
    Do I need to solder a wire from one side to the middle of the pot?
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    er...
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    I think there's a bit too much "pot" going around, if you know what I mean...
    I found these links to be much more useful than that diagram. Two of the best tutorials (in my opinion) are:
    IceHardware
    and
    this one
    Hopefully one of those will explain it for you.
    Whether you need a potentiometer will depend on whether you want to be able to adjust the backlight. You could wire in a switch to change between full power and half power for day/night use, or just use the pot to adjust it to a comfortable level. Either way, check the specs on your LCD. I found my LCD needed 4.4v, while one of the sites said straight 5v is okay. Had I wired it that way, I would have fried the backlight. Check and double-check your specs. I've even had two LCD's from the same manufacturer use different specs.
    Good luck,
    Kris
    Aug 2004
    Central New York
    thanks! great links! sorry about the stupid question just a little new
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    linking the 2 pins of the potentiometer turns the pot into a rheostat, but it should not be required for correct operation.
    -Mars
  1. 4x40 char LCD EL backlight & inverter. sell or trade...
    By Jarrod in forum Classified Archive
    Last Post: 03-06-2002, 10:31 AM
  2. Replies: 8
    Last Post: 05-03-2001, 05:42 AM
  3. 4x20 lcd, 4x40 lcd with keys, num. keypad
    By RaZor in forum Classified Archive
    Last Post: 04-17-2001, 11:19 AM
  4. Looking for Display 4x40 or LCD?
    By Squeeky in forum General Hardware Discussion
    Last Post: 01-17-2001, 01:25 PM
  5. Looking for Display 4x40 or LCD?
    By Squeeky in forum General MP3Car Discussion
    Last Post: 01-16-2001, 03:21 PM
