Results 1 to 6 of 6
Thread: Lilliput Touchscreen only works sometimes
    Newbie XeroDSM's Avatar
    Jul 2004
    Blacksburg, VA
    Pretty much my touchscreen will only work half the time I turn my computer on. I have no idea why, but half the time I turn it on it works perfectly and then the other half it won't work at all. The monitor always works and I know all the cables are in right. It doesn't seem to have any pattern to it either, I can have it working, turn it off and it won't work when I turn it back on then turn it off again and turn it on and it'll work fine. Does anyone have any idea what could cause or more importantly fix this problem? Thanks.
    Constant Bitrate bulgogi777's Avatar
    Jun 2004
    NW FL
    Do you have a mouse attached to the system in some way? I have a gyration mouse, and for some reason it interferes sometimes with the operation of the touch screen. Haven't exactly figured out why... Just a thought...
    90% done - Sempron 64 2600+, MSI RS480M, 512mb, 80gb hd, 7" Lilliput, 802.11g pci, Itrek gps, Panasonic slim slot DVD/CDRW (broke :( ), Hauppage Wintv, Iguidance 2.0, Opus 150w, Griffin Powermate, Optima Yellowtop, Infiniti 6002i & 9603i
    My Install
    Aug 1999
    Washington D.C.
    Do you have any bluetooth devices installed?
    The touchscreen is powered by the USB bus and will work even when the monitor is turned off.
    Jul 2004
    Blacksburg, VA
    I don't have a mouse or any blue tooth stuff hooked up to the monitor, it's the only thing using USB and I really don't even have anything installed on the system other than the programs to get the touchscreen working... Any other ideas?
    Aug 1999
    Washington D.C.
    Did you install the touchscreen drivers before connecting the monitor to the computer?
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    Tried a different usb slot? I had problems with mine, had to reformat
    CarPC status: iPod, 3,456,217 songs so **** you
  1. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  2. unable to get touchscreen on lilliput
    By delussional77 in forum LCD/Display
    Last Post: 05-23-2004, 07:22 PM
  3. FS: Lilliput TOUCHSCREEN CONTROLLER
    By CDesigns in forum Classified Archive
    Last Post: 05-13-2004, 11:35 AM
  4. exact outer size of 7" lilliput touchscreen?
    By cotwild in forum LCD/Display
    Last Post: 01-08-2004, 01:43 AM
  5. Replies: 15
    Last Post: 01-05-2004, 04:40 PM
