Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 66
Thread: LILLIPUT (what do you expect)
  1. #21
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    Quote Originally Posted by Chairboy
    Well this is embarrassing, I should have thought to ask if you had a firewall, I was the manager in charge of QA for Norton Internet Security until a few months ago.
    hahaha,,, embarassing for me
    throw a moon
    heuvos vin chevos
  2. #22
    Aug 2004
    tx, USA
    Red face
    damn,, disabled auto protect and still same error......
    edit: changed every setting i can damn near think of that would do anything, as im not even using norton,, but still same error
    we got the pro nortonEr in here,, whats your input mayne
    throw a moon
    heuvos vin chevos
  3. #23
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by PaCMaYNE
    You probably have all this stuff checked....but...
    Can you ping the computers?
    You have P&F Sharing enabled on both PCs?
    You have them on the same Workgroup name?
    Make sure are appropriate services are started/enabled.
  4. #24
    Aug 2004
    tx, USA
    i havent tried pinging,,
    both on defualt workgroup
    i have both c drives enabled for sharing,, only the m1000 is showing up(on the m1000), and i dont have norton installed on it yet
    i have to be missing one little detail,, im still guessing its related to norton,, but im gonna redo all the settings and see what happens
    throw a moon
    heuvos vin chevos
  5. #25
    Aug 2004
    tx, USA
    throw a moon
    heuvos vin chevos
  6. #26
    FLAC Chairboy's Avatar
    Jan 2004
    Autoprotect is antivirus, not firewall. To test if it's NIS, right click the globe icon in your systray and select 'Disable Norton Internet Security'. After that, try the network. If it works, you do one of the following to configure NIS to allow that network traffic:
    Open up the integrator, double click the Firewall tab on the left. You'll want to modify the firewall rules. Find the ones that mention Microsoft Networking and uncheck the ones that disable it.
    Or...
    you can add the IP address of each machine to the others 'trusted zone' in NIS. Then all traffic is allowed between them.
  7. #27
    Hayling Island, UK
    PaCMaYNE: i can host that vid if you want, pm me.
    I take it both pc's are plugged onto a switch/hub or into each other using a X-over lead.
    are you ips something like this 192.168.0.XXX and subnet 255.255.255.0?
    Just going through the obvious
  8. #28
    Aug 2004
    tx, USA
    i worked out the lilliput prob mayne,, the main prob im having now is sending all my **** to my epia.... i can get everything working on my epia but not on my desktop pc... which leads me to believe its a freakin norton thing,, even though i have diabled damn near everything and stil cant get it to work.. ill post a pic in a sec of the exact error message
    throw a moon
    heuvos vin chevos
  9. #29
    Aug 2004
    tx, USA
    even if all the variants were incorrect,, it should still show my pc under my workgroup,, and yet nothing .... this is quite annoying as shat
    throw a moon
    heuvos vin chevos
  10. #30
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    My solutions:
    1 you could forget trying the "workgroup" all together. This is what I do at my Clients' office. Go to Start> search >printers, computers...> computer.
    Put in the IP address in the Computer Name field.
    2 Just for clarification you are not running Norton Internet Security or any other firewall? FYI, your workgroup name is NeTWorK not the default according to the pic you posted.
    3 Check the settings of the windows internet connection "firewall" (on the network connection properties field).
    4 Was the computer ever connected to another computer?
    5 Was the computer ever on a client server network?
    On the net:
    1 Is the Computer Browser service started?
    To start/stop Master Browser on Win2K/XP, go to Administrative Tools>Services, start/stop the Computer Browser. You setup start automatically, select Administrative tools, Services, and change the Start setting for Computer Browsing to Automatic. You can then reboot the computer or start the service manually by clicking on the Start button.
    2 NetBIOS over TCP/IP. To do that, go to the properties of TCP/IP>Advanced>WINS. If you are using a static Internet Protocol (IP) address, click Enable NetBIOS over TCP/IP. If you have a DHCP-assigned IP address, click Use NetBIOS setting from the DHCP server.
    3 No Master Browser or too many browsers may cause this issue Change master browser in w2k or XP:
    Go to Program files, Admin tools, services then in the right panel right click on computer browser and right click go to properties then from the startup list select Disabled. Or type regedt32, and scroll to this key change value to False
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Browser\Parameters IsDomainMaster=FALSE
    Hope that helps
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  3. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  4. FS: Parting out Lilliput
    By 047025n in forum Classified Archive
    Last Post: 06-26-2004, 08:52 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
