That looks like the connectors on AIX Terminal boxes... They look like LPT ports and the screen are 2 colors.
I could be wrong though, so don't quote me on this.
So what is the LVD port found on the VIA mini-itx mobos? It's 40 pin, can that connect directly to the lcd, w/o the vga controller?
But can I send information needed to run this device throu lpt port with some program??Originally Posted by nl4jy
So I passed 6 and also 12 v throu pins and quess what happaned.
The screen went grey and blue but nothing else.
But if it went blue it means that it is color screen.
Can I use some program to communicate throu LPT port
The problem is you first have to find what pins go where, the LPT port has 8+ data lines and if any of those are hooked up wrong you wont get anything. I am almost willing to bet that the display needs a special controller card that will be hard to find. Can you get the model number from the back of the actual LCD panel itself?
There is a display controller unit PCB 1002B.
I could not find any information about this controller.
Not the numbers from the controller, the numbers from the back of the lcd the actual panel that displays things.
