I think this is the same as the Coyote Auto on lilliput mod.
My solution to Auto Power ON Lilliput screen
I have put in this tread as to modify the lilliput to have automatic power through Igniton On.
If it is able you' to interest..... link here http://www.mp3car.com/vbulletin/show...1&postcount=51![]()
Bye
Mauri
And' true, are right!Originally Posted by antimatter
However if you make the connection as it says him you lose the I use manual of all the buttons of the lilliput (at least with mine it did so) instead eliminating the R. from 10K original and putting to place that from 150k, and' everything ok.
The cond. and' better in SMD and tantalum, however him' and' practically then as also made Coyote.
Better, sign that then it also works to others![]()
Mauri
If understand this correctly, mauri's mod makes the lilliput turn on automatically and still keep the functions of the keys and coyote's mod just turns on the screen. If this is correct can someone explain how to do mauri's mod, because I may having a little bit of difficutly understanding, I do not know much about resisters and such.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
I thought Coyote's mod allow the buttons too. The mod that kills your buttons is where you short the contacts for the button so it emulates the power button being held down, that's the one that locks you out of your panel buttons.
So what is the difference between mauri's mod and coyote's mod?
Installed
Originally Posted by Quattro-A4
Coyote's was posted 8 months earlier?
SeeYa! -Jim-
Buttons still work with Coyote's mod!
In my lilliput if I do as had posted coyote all the keys are disabled.Originally Posted by Laidback
Then you it does as it seems better you.
This way' as I have done me to me it works, as coyotes didn't work the keys.
It looks that I don't have at all to sell the solution of the thing!.
I have perhaps brought simply one experience of mine profit to someone other, then you see you...
Mauri, is it possible that you made an error while implementing Coyote's fix?
