Results 11 to 20 of 22
Thread: Smaller VGA Touchscreen module
  1. #11
    Feb 2003
    Atlanta
    ur saying the touchscreen overlay is what makes the difference? either way i go will be touchscreen
    i specc'd it today without the chrono pack, as i'm abandoning the idea of putting it in the center circle for now (can still change mind for next week or 2)
    that pic isn't a photoshop so far as i know...someone on mini2 posted that...i need to find the thread/writeup/member to get more info on the details of installing it...
    i think i'll take cut a piece of abs plastic and then cut a hole out the size of the touchscreen and use just the lcd module sticking out of that (no casing around the lcd)
  2. #12
    Variable Bitrate mutilator's Avatar
    Jul 2002
    Staffordshire - united kingdom
    hmm, ok that might work. youll still probly have to hack up the downpipes, i think anyways, cant remember just how wide they are
    ... on the other hand, if the tm701l goes in, there must be room between em. yea mabe im talkin crap.
    heh
    keep us posted.
    tom.
  3. #13
    Feb 2003
    Atlanta
    yeah, a 7" screen fits in a din-sized unit and since the downpipes are a din-sized wide (so u can put in hu)...the main issue is moving all the stuff down and how hard that is (wire length, mounting brackets, etc)
  4. #14
    Jul 2002
    well the hu has a plastic thing underneath it... when u remove the aircon unit you may find you will need to hack that up a little.
    as for movin everythin down im not sure how youd go about it. definatley need to hack the downpipes up.
    tom.
  5. #15
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    the lilliput will fit, but the xenarc is about 3mm to wide for a din housing.. but you can saw off the side bits to make it fit... just thought I would let.. might help
    cheers
    CdR
  6. #16
    Feb 2003
    Atlanta
    ok, then lilliput it is!
  7. #17
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Just curious,
    You are not getting the nav option, correct?
    If you are, you can try interfacing the unit with the IBUS. Do a search on IBUS interfacing. It is pretty cool
    Of course, if you are not getting the nav/screen, then I guess I am just rambling on for no reason, sorry.
    Michael
  8. #18
    Feb 2003
    Atlanta
    i'm not getting the nav screen, no
    however, i'm still going to interface my carputer with the ibus...i can get an adapter board and then read info into my carputer...should also be able to use my steering wheel controls to control the carputer (better be able to...i paid 250 extra for that wheel)
  9. #19
    Jul 2002
    nicholas, the xenarc will prolly fit. think about it, the lili fits in teh tm701l housin. the xenarc is 3mm too wide... the housin is prob 2 mm wide.. and the downpipes are probly 2mm away from that.. should fit...
    tom.
  10. #20
    Feb 2003
    Atlanta
    yeah...but the lilli is cheaper i think
    ;o)
  1. VGA vs RCA & Touchscreen vs other
    By integsrtite in forum LCD/Display
    Last Post: 12-02-2004, 07:07 PM
  2. Replies: 9
    Last Post: 06-30-2004, 06:21 PM
  3. any VGA smaller than 7" ?
    By zerosiggls in forum LCD/Display
    Last Post: 06-25-2004, 09:35 PM
  4. Replies: 3
    Last Post: 04-03-2004, 11:21 PM
  5. Xenarc 7'' TFT Touchscreen VGA for Europe
    By VooDoo1999 in forum Classified Archive
    Last Post: 06-19-2003, 05:47 PM
