Results 1 to 9 of 9
Thread: Lilliput only uses a portion of the screen
    Nov 2003
    Olympia, WA
    I have a lilliput..non-vga...I know, not the best idea. So when I run my carputer it doesn't fill up the entire screen. I've played with all the settings and there's still a portion of the actual screen that isn't filled up. There's a a portion of the screen on both sides that's roughly an inch and a half that doesn't display anything. Did I miss a setting or something on my carputer?
    Constant Bitrate sagekoala's Avatar
    Aug 2004
    Des Moines, Iowa
    overscan?
    if you tweaked with your overscaning you might be able to work something out. i have no idea how to do it on a windows box. sounds like something powerstrip might be able to help you with, but idk I've never used it
    don't worry i know i usually don't make much sense
    Nov 2003
    Olympia, WA
    I'll give powerstrip a shot when I get home. It's also shaking...something that I forgot to mention. I think I can change the refresh rate in powerstrip too.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    The Lilliput IIRC has different "zoom" modes, which can display a 4:3 image (which is what you're getting from the PC) as either normal mode (which is what you're seeing, with black bars down the side) or in "stretched" mode, which is where it will stretch the image to fill the screen.
    This should be an option within the menu/remote of the Lilliput
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Nov 2003
    Olympia, WA
    Quote Originally Posted by Confused
    Garry
    Is that only for the vga models? the 'stretch' 4:3 option? I do have two options for 4:3 but neither of them fill the screen. I'm going to give powerstrip a shot this afternoon to see if that makes a difference.
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    what model do you have?
    Nov 2003
    Olympia, WA
    Mine is non vga...not sure on the model tho..i'll have to find the box.
    Aug 2003
    Essex, England
    AFAIK, that option is only there for AV inputs. (VGA inputs will automatically use the entire screen I think)
    Garry
    www.aimee.cc
    Nov 2003
    Olympia, WA
    okay it took some tweaking but i got it to where the screen is filled displaying at almost exactly 16:9...i found a thread that mentioned going into advanced settings for the display to get a better resolution. i also had to choose 'underscan' in my cmos settings. that seemed to do the trick. thanks for the help everyone....but vga would still be better.
  1. My solution to Auto Power ON Lilliput screen
    By coyote in forum LCD/Display
    Last Post: 08-15-2011, 07:56 AM
  2. Replies: 4
    Last Post: 09-01-2004, 02:02 AM
  3. Problems with new lilliput touch screen panel?
    By markc04 in forum LCD/Display
    Last Post: 08-27-2004, 02:38 PM
  4. Lilliput FULL SCREEn
    By ericdee in forum LCD/Display
    Last Post: 05-05-2004, 05:18 PM
  5. Lilliput.. 7" No Full screen ???
    By Lazyboy62 in forum LCD/Display
    Last Post: 02-15-2004, 01:38 PM
