Results 11 to 20 of 22
Thread: Lilliput blue lights
  1. #11
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by jpelzer
    Oh, and to answer the "change the color" question, it'd be easy if you are comfortable with soldering surface-mount components. Otherwise, not so much.
    I'm willing to try it. It going to be and eye sore to have blue lights on the screen when everything else in my car is red, it would look out of place. So if you could point me in the right direction on to change the color and what I need to do, it would be greatly appreciated.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #12
    Elsewhere
    Quote Originally Posted by Nic
    remember frodo....
    I just couldn't resist
    http://www.ultimarc.com/ipac1.html
    OK, when you smack down Frodo like that, is it considered spanking the monkey?
    Just wondering...
    How about the Wiki?
  3. #13
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
  4. #14
    Constant Bitrate jpelzer's Avatar
    May 2004
    NYC
    LOL, yeah. That's the link. Ultimarc...
    Bush: Proof that humans really did evolve from apes.
  5. #15
    Oct 2002
    UK
    Well, I just found the paper, and it looks like I wrote down what each wire went to after I'd soldered them to the board. So that doesn't help you very much.
    Basically, what I found is that the blue LED's have a shared positive and negative terminal. They all turn on/off together. I feed them 4.5 volts and they run perfectly.
    The buttons all share a common lead, and then each come to the connector individually.
    The power LED uses the same common ground with the buttons, and then has a separate lead for red, and a separate lead for green.
    I determined all this by following traces, and experimenting with a continuity tester.
    where did u get the 4.5v feed from? so you simply connected a 4.5 volt source to the rail feeding the positive feeds to the leds?
    Volvo C70 - Installation in progress *gulp*
  6. #16
    Oct 2002
    UK
    Just found this:
    http://www.tmz.com/wrx/lilliputLCD.html
    At the bottom of the page it says to connect pin 12 to pin 8 to keep the blue leds on.
    Anyone tried this?
  7. #17
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    its very simple connect pin 12 to pin 8.
  8. #18
    Oct 2002
    UK
    Quote Originally Posted by kickercivic1
    I figured that anyone done it though?
  9. #19
    Variable Bitrate NRGZ28's Avatar
    Oct 2004
    Las Vegas
    I just did that tonite. Took me 5 minutes tops :P Very easy to do...
  10. #20
    Oct 2002
    UK
    Quote Originally Posted by NRGZ28
    So it worked out ok then? Tried finding pin 8 and 12 on my screen and it doesn't even seem to match up... did yours have excatly 12pins?
  1. WTB: BROKEN Lilliput 619!
    By masch in forum Classified Archive
    Last Post: 12-14-2004, 04:58 AM
  2. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  3. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  4. Replies: 2
    Last Post: 06-20-2004, 12:10 AM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
