Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Lilliput blue lights
    Oct 2002
    UK
    Just got my 7" touchscreen Lilliput quite happy with it.
    Is it possible to hack the screen to make the blue lights stay on all the time?
    Also, the touchscreen overlay I have seems to be a poor quality... not sure if there all like this but mine gives a grainy look to the screen, when you touch the overlay you can see it move slightly. Also the brightness isn't too good... i've heard its 400nits without the touchscreen and only 280 with.
    Can i do anything about the brightness? I suppose I could take the overlay off.
    cheers
    Volvo C70 - Installation in progress *gulp*
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    I don't see why you couldn't just hook the lights right up to some external power source...?
    Constant Bitrate jpelzer's Avatar
    May 2004
    NYC
    I have my lilli totally hacked, so the lights come on when the headlights are on. The keys are wired into an i-pac (basically a keyboard interface) so they control FrodoPlayer (or whatever)
    It was a pain in the butt to do, but well worth it. If you want to hack, I might still have the piece of paper lying around that had the pinouts for each key and the lights.
    Bush: Proof that humans really did evolve from apes.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I had a similar question about the lights, is it possible to change the color of the lights to a different color, lets say maybe red?
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Dec 2003
    New York
    Quote Originally Posted by jpelzer
    It would be nice to have the lights hooked up to your headlights. Could you post the pinouts and maybe some instructions on how to do this?
    Installed
    May 2004
    NYC
    Well, I just found the paper, and it looks like I wrote down what each wire went to after I'd soldered them to the board. So that doesn't help you very much.
    Basically, what I found is that the blue LED's have a shared positive and negative terminal. They all turn on/off together. I feed them 4.5 volts and they run perfectly.
    The buttons all share a common lead, and then each come to the connector individually.
    The power LED uses the same common ground with the buttons, and then has a separate lead for red, and a separate lead for green.
    I determined all this by following traces, and experimenting with a continuity tester.
    May 2004
    NYC
    Oh, and to answer the "change the color" question, it'd be easy if you are comfortable with soldering surface-mount components. Otherwise, not so much.
    Super Moderator xBrady's Avatar
    USA
    Now that would be cool.
    Installed.
    -GPSSecure- - GPS Tracking
    Jan 2003
    Ruston, LA
    Gimme a link for the i-pac, I wanna look at it.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    remember frodo....
    I just couldn't resist
    http://www.ultimarc.com/ipac1.html
    Signature: [==||========] 20% complete
  1. WTB: BROKEN Lilliput 619!
    By masch in forum Classified Archive
    Last Post: 12-14-2004, 04:58 AM
  2. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  3. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  4. Replies: 2
    Last Post: 06-20-2004, 12:10 AM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
