Get the one from here silly.
I'm looking to get an extension cable for the lilliput, however where should i go to get the cable?
I have found these places that carry a mini din 9 pin cable
http://www.stockcable.com/minidin.shtml
http://www.computerplug.com/cable_mo...s-ext-tech.htm
http://www.mp3car.com/store/product_...products_id=46
And this place that carries a rgb extension cable
http://www.pccables.com/cgi-bin/orde...search=MONITOR
I have already gotten this cable from cablewholesale
http://www.cablewholesale.com/cgi-bi...text=minidin+9
The cable that i have does not work that good because it does not transmit red, all the other colors come in fine and the picture is sharp, just no red.(i do get red if i dont use the cable)
I already have a usb cable run to the front of my car so running a rgb ext. cable is not a problem for me.
What i would like to know is which place would i get a good reliable cable from as far as the min din 9 pin cable is concerned? Has any one else gotten cables from any of theses places that they would recommend?
Or should I just run a rgb cable? would i notice any difference between the rgb and the mini din cable?
amd 1700, biostar m7ncg 400, hitachi deskstar 120 8mb , 512 pc2700, liliput 7"
now to put it all together
[H]4 Life
I'm a lesbian too.
I am for hire!
Or even from here
The cable you picked up looks like the same one thats for sale here. The specs are also the same too.
Status: [|||||||||-] 90% finished
My 2000 Chevy Monte Carlo SS Install
The cable that is on sale here is only 6 feet long, I would think you would need a longer cable if the computer is in the trunk.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
That is what i noticed too. call me paranoid but I want to make sure that the cable that I get will work, i guess what im looking for is first hand experience with that cable.Originally Posted by snmnetwork
I'm sure mp3car.com will sell me a quality product that will work. I'd just like to hear what other peoples experiences have been
Also, are the ones at mp3car.com actually 6ft? because the ones i got from cable warehouse were more like 9, even though the invoice said six footers
I will need about a 9 feet of cable to do the run in my car
I agree with you. I just ordered that same cable from here today for $9.99. I hope I don't have the same problem you have, because those 2 cables are identical. Even the store display pictures look the same. Time will tell tho.
If it doesn't work out I will be ordering this one http://www.computerplug.com/cable_mo...s-ext-tech.htm
I'm almost 99.9% sure this is the correct one.
Just received a 12 foot extension from stockcable.com. Shipping was as much as the damn cable, but got here quick. Would have got it here if they had 12 footers. Tests out perfect no loss of Video or USB signal. Still sitting on the test bench though, hope this stays true in my ride.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
Check Pin one for continuity...if you want to fix it the pinout for RGBHV is:The cable that i have does not work that good because it does not transmit red, all the other colors come in fine and the picture is sharp, just no red.(i do get red if i dont use the cable)
pin 1=Red signal
pin 2=Green signal
pin 3=Blue
Pins 6-10 Ground
Pin 13 Horizontal signal
Pin 14 Vertical signal
