Buy yourself some molex connectors and wire one where the cigratte lighter plug was.Originally Posted by Avalerion
get a voltmeter and check the cables,, most likely the black with white stripe is positive,, as far as wiring,, i would cut off the molex and hardwire those bastards together,, and ground to the chassis
throw a moon
heuvos vin chevos
arch you lost me on there??? why would you need a molex connector if you are going to plug to a 12+ thats comes from cigratte lighter.
What I meant was when you cut off the cigarette power adapter and just have the positive and negative power wires, you should wire them into a molex connector. That way you can just plug it into the molex connector of the PSU.Originally Posted by kickercivic1
No reason to go splicing wires in your PSU when molex connectors are already there for plugging things in.
for car use i perfer hardwiring or using molex connectors with plastic hooks(that allow the m/f to clip onto each other), its too easy for a male and female molex (standard computer) to slowly wiggle away from each other and leave you ****ed off and have to pull out half of the system trying to find the problemOriginally Posted by archimense
[Car]-[2001 Civic Ex Sedan]
[rebuilding mp3 box]
MTVideo DVD/TV Tuner
MATX Celeron 500mhz
7inch Overhead Liquidvideo Dvdplayer For Trade Looking for ~7inch LCD Touchscreen preferred.
5inch LCD w/ stand also for trade
OK as promised here is the link to some pics of the conversion
http://members.iinet.net.au/~supa/ca...conversion.htm
