black white stripe= positive,,,,,,usually
chech with a voltmeter
Can someone help me out? I have to hook up my Lilliput but I cant remember which polarity the tip it on the power connector that plugs into the back of the lilliput. It used to be hardwired to my carpc's power supply but when I was redoining it I removed everything. I fried my egg originaly because I acidently reversed the polarity. I found a nice adapter that regulates the power to 12.3V with the engine running and it only drops to 11.6V with engine off. I just need to make sure I atach the connector on the end right so I don't Fry my lilliput. By the way I did. Thanks in advance to whoever can help me.
2002 Oldsmobile Alero GL2 4DR
Aleroputer 90% done (ripped out and being rewired)
MYMODS:
Pioneer Head unit in a remote location, Clarion Amp, XM Satilite Radio, 2 10" Audiobahn DVC Subs wired 1 ohm in a bandpass box, Grill Mesh, Halo Guages
throw a moon
heuvos vin chevos
On mine, the tip is positive.
outside is neg,, inside pos.... 98 percent of the time
throw a moon
heuvos vin chevos
Same as everyone else said. But test with a voltmeter to be sure. If you don't own one, its a great $10 walmart investment. Go get one!![]()
take a meter and check dont depend on anybody. $300 screen will be gone in matter of second if its pluged backward.
I have a $300 meter. Only problem is I have already hacked up the AC adapter for another prodject and all I have left is the cable that came out of the car adapter egg. I wish I could test something with a meter But I have nothing to test, which is the reason I asked. Btw I just realized this could sound rude but its not meant to be. Thanks
MYMODS:
Thanks Rando
MYMODS:
Originally Posted by aleromaster
white stripe is positive
