Results 1 to 9 of 9
Thread: Auto video switch on lilliput
    NEO
    NEO is offline
    Newbie NEO's Avatar
    Oct 2003
    Åmynnet, SWEDEN
    Any one no how to make lilliput auto switch vga > video1 and back
    whid help of the rewerse light
    Everyting that has a begining has to have a end
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    It shouldn´t be to difficult to have a pulse generated when the reverse light turns on. The big problem is that the lilliput button cycles thru tree inputs. We had to achieve a way to generate one pulse when reverse on, and two pulses when reverse off.
    It will probably be easyer to get this done by software. Use a usb cam and some type of serial controler ( Frodo have done this to disable video when handbrake is off, by using only a relay, and there is already around a small app to display a usb cam window). When reverse light is on, your app would get a usbcam window on top, when reverse off the window would go away
    It would be great if possible.
    Brave
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Shreveport, LA
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    hard bit is knowing which mode the monitor is in. You can easily get the reverse light to simulate the AV/TV button on the lilliput but as it's a toggle on momentary if you have already manually switched it to TV it will then switch it to VGA.
    Jun 2000
    NYC
    yeh, I trying to figure out the exact thing for my lilli. I heard those cheese boxes are expensive though. This is mostly for cool factor, so I would like to keep the costs down.
    I also want to avoid opening the Lilliput up and voiding the warranty.
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    Yes use a cheese box. They aren't too bad -- like 50 bucks. Check ebay. They are sold there from time to time.
    Note that the cheeze box outputs 640x480 and my computer is set to use 800x600 -- sometimes the lilliput has problems resyncing. While the computer is booting it's not too bad.. Obviously if you run your desktop in 640x480 you will not have any trouble either..
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    If someone wants to poke around their Lilliput controller board with a meter or scope, you may be able to find a signal (or signals) which can be used to detect which mode it's in (VGA, Vid1, Vid2). If you had that, then the cycling wouldn't be so bad.
    I've been wanting to do this, but have no desire to rip my screen out of the truck (again) and crack it open. Someone getting ready to do the Cayote mod on their screen would be in a good position to get an answer for us.
    Jun 2004
    Shreveport, LA
    Is there something cheaper than the cheesbox that does the same thing?
    Creative solutions?
    '03 Escape 4WD:
    -Transflective 8.4"
    -Slim Slot DVD+RW
    -RR, DFX 4
    Aug 2003
    Amarillo, TX
    Nope. The cheese box is, by all standards, insanely cheap for a scan converter. You might get lucky with something on ebay, though it may not be as easy to hack as the cheese box. I got my cheese box for about $25 from ebay.
    One reason the cheese box is easy to hack for this purpose is that the switch that toggles between the VGA pass through input and the composite video input is a cheap DPST manual toggle switch that can be replaced with a 12V DPST relay triggered by the reverse lights. Any other scan converter i've ever seen has an electronic pushbutton 'mode' switch -- and if you could toggle that type of switch cheaply, you could simply toggle the lilliput's video input button instead of bothering with the scan converter in the first place.
    MY CAR IS FOR SALE!
  1. need help with lilliput RCA video input
    By CDesigns in forum LCD/Display
    Last Post: 04-04-2007, 06:33 PM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 06:06 PM
  3. lilliput video 2
    By vipergda in forum LCD/Display
    Last Post: 07-14-2004, 06:26 PM
  4. How do you save Lilliput video settings?
    By ML430 in forum Input Devices
    Last Post: 06-09-2004, 11:37 PM
  5. LCD video switch for the car
    By Mwilhelm100 in forum LCD/Display
    Last Post: 11-20-2002, 07:03 AM
