Results 1 to 10 of 16
Thread: Do you need a very compact graphic fan controller?
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    I have been searching for a really small fan controller with some cool graphics (eye candy) for a while. The problem is that I have a very small area to place it in, and most of them have large pcb's with knobs or buttons on them. Then I found this one sweeeet! Well pretty sweet, the clock is kind of small (I have one anyway) and the date is yyyy/mm/dd (also on my clock) , that's weird. But it has a cool spinning fan on the display, three selectable fan's cpu, hd and system, each one has its own temperature probe. It also has a temperature alarm that you can set. It has a hd status display (same function as led on the front of a pc), Oddly enough it even has an alarm clock, and a few other functions.
    So if you have wanted to add something like this to your car, but didn't think that you had enough room, maybe this one will work for you. I have measured it, for those interested.
    SilverStone Eudemon SST-FP52-S right out of the box.
    Disassembled:
    I put the quarter in there for comparison. The knobs were hot glued on so I used a lighter to remove them. The knobs are a aluminum shell with a plastic insert, so they were slightly damaged but they could be hot glued back on. You will either have to remove the knobs or cut the bracket to get them out. The buttons are on a separate pcb, I like that, it will be so easy to put the buttons anywhere I want. The backup battery (3 volts I think) is also on its on pcb (easy relocation).
    Now for the sweet part, the speed of the fan graphic changes with the actual fan speed and of course you can control the fan speed. It has a pretty big temperature display that can be changed to Fahrenheit or Celsius. I didn't have everything connected when I took this photo, that's why there's no power or hd status.
    Ok, here are the dimensions as promised.
    I have other projects to finish so I put it back together. It's going to be a while before I can get around to installing this, but I look forward to having the CPU temperature at a glance.
    I hope this is helpful to someone.
    It's the cake having/eating thing.
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Damm, that looks cool..
    I guess is one more to add to the todo list
    You forgot the link: http://www.silverstonetek.com/products-fp52.htm
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    That's SWEET!!!!
    Although you can do this with a character LCD and speedfan... But this is damn small!!!
    And the buttons are on separate PCB!!!
    Are they normal push buttons?
    Can the fan speed be controlled automatically (dependable to CPU or SYS temp)???
    Is suppose it can stop the fans... 0V
    How long can the wires for the temp sensors be?? (trunk to dash)
    Also could 6-12V be variable? Or does it give 6 OR 12??
    Super Moderator xBrady's Avatar
    USA
    Holy crap that looks sweet! Where do you plan on placing yours? How much did you pay for it?
    Installed.
    -GPSSecure- - GPS Tracking
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by DjBac
    That's SWEET!!!!
    Here's a link to silver stone I'm sure they have all that info. http://silverstonetek.com/products-fp52.htm
    I need to make the wires longer also. I plan to lengthen one and put all the probes in the same place to compare the temperature difference. However I didnt plan on going as far as you. I will probably end up extending the wires about 5-6 feet. Do you have any idea how long you would need the wires to be? Maybe I could test at the length that you would need.
    It runs off the pc power supply. The 12v is for the fans and back light. The 5v is for every thing else.
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by brady
    I have two places, one is in the overhead console where my clock is now, but then I will have to relocate the clock. The other would be where the ashtrey is now (I like this better).
    I got it from newegg $32.99
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Hey this is really cool. Very good post with great pictures and pinouts and everything.
    Jun 2003
    Memphis - TN
    is it possible to display other than the pre-set. Think it could be used as a standard LCD if you attached a parallel cable to specific pins?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by more mods
    I think I will need about 13 feet of each cable!!! AT least!!!
    I meant if the volts that are for the fan could be changed at different amount!! So that you cacn control the fans at any speed up to 6V!!
    Dec 2003
    Porto, Portugal
    ...but then I will have to relocate the clock.....
    or trash it completly. The silverstone already has a clock
    Status -->
    BraveCar 2.5
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. Xenarc VGA Controller Features
    By 1300mer in forum LCD/Display
    Last Post: 07-05-2004, 01:46 PM
  3. FS: M1023 Rev E controller + inverter + 10.4" screen
    By jusatry in forum Classified Archive
    Last Post: 05-12-2004, 03:09 PM
  4. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
  5. Trade 8.4" LCD with controller for Alan controller
    By Sleeka in forum Classified Archive
    Last Post: 05-15-2002, 12:09 AM
