Results 1 to 4 of 4
Thread: Lilliput connector problem? is there a fix?
    May 2004
    I've read on this board before how people have had issues with the DIN connector for the Lilliput where the VGA/USB cable connects. People say to pinch the connector because there is a bad ground connection. I am constantly having to adjust my connector and wire due to the screen flickering on and off and it is very annoying. Is there a way to fix this connector or replace it with something more efficient?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Cut it up and splice it together.
    Tidder
    Try RevFE
    Mac Car Moderator kandyman676's Avatar
    Maryland
    that is all you can really do....replace the plug with some other connector. I have a problem with my DIN plug causing the LCD to turn green with a short EXACTLY in the DIN plug. I will have to cut mine up and splice it into serial plug ends to make it work.
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
    Aug 2004
    I just got rid of the connector all together and shortened the vga cable.
  1. Replies: 88
    Last Post: 09-15-2004, 05:38 PM
  2. FS: 7" Lilliput Touchscreen VGA Monitor : Broken
    By jaeger in forum Classified Archive
    Last Post: 08-21-2004, 07:46 AM
  3. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 08:41 PM
  4. How to fix bad lilliput vga connection?
    By chargin in forum LCD/Display
    Last Post: 07-22-2004, 04:27 PM
  5. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
