Results 1 to 8 of 8
Thread: Lilliput won't pwr up .. Help!!
    Newbie bdqpdx2000's Avatar
    Cranbury NJ
    Angry Lilliput won't pwr up .. Help!!
    I took my new Lilliput out of its case to mount it in a custom bracket for my Impreza, reconnected everything, and figured I'd power it up just to make sure it was still working ... it wasn't. The whole thing just seems completely dead. To eliminate the obvious, I tested the transformer output with a multimiter... works fine. Everything on the board looks perfect.. nothing burnt / blown / busted / loose. I'd hate to have to buy another one, since I'm sure whatever problem I'm having is fixable. Help!!
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    return it
    Cranbury NJ
    Well see here's the thing... it worked fine before I took it apart (in the interest of fairness) .. and I already cut the case to take out the VGA cable, so I think they'd notice that.
    Aug 2004
    Brampton, Ontairo
    The same thing just finsihed happening to me, the blue LEDS on the button board flast quickly when the power is applied, any ideas would be great, tested each connector nothing, I did un solder the IR eye and add wire to extend it
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    the ribbon cable that connects the buttons to the screen has 8 pins/leads yet the connector on the controllerboard has 9 pins. Sometimes when you seat the cable you may be one pin off or half way inbetween. Make sure you push the cable all the way to the left(from what i recall) before pushing down on the side tabs to hold the cable in place... do a search and youll find some pics.... Good Luck
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
    Cranbury NJ
    Yeah I figured that one out on my own. Looking at the button board from the back with the IR receiver on the top, the ribbon cable needs to be all the way to the left. I had that same problem before my screen blew completely...
    Aug 2004
    Brampton, Ontairo
    I had that problem also, now the screen turns on but no picture gonna have to assume it is the other ribbon cable, will play with it in the morn as it is now to dark to play around with it
    Cranbury NJ
    Any other ideas anyone?
  1. Replies: 118
    Last Post: 10-22-2010, 03:05 PM
  2. Replies: 88
    Last Post: 09-15-2004, 05:38 PM
  3. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 08:41 PM
  4. FS: Parting out Lilliput
    By 047025n in forum Classified Archive
    Last Post: 06-26-2004, 07:52 PM
  5. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
