> How mod'able is it? Can I remove the case / button bar? Is it as fragile as the lilliput?
The new model is more sturdy then a lilliput. You can remove the case, no problem. The button bar can be removed, but the actual switches are soldered on the controller board. The cables are long enough to be able to move the controller board up a bit.
> Does it auto-power on after power gets applied?
Yes, it even goes in standby if no signal is applied, but awakens is signal is applied. OSD always informs about going into either mode.
> What is that Ultra-Brightness thing they have on Xenarc Direct? Is it worth $195 ?
It's what it says, but I have the unit without. It's very bright though, even in direct sunlight (and I have it mounted pretty uncovered/no tinted windows).
> Do you ever need the button bar?
I don't. I have soldered a little flatcable to the switches to be able to use them, but have not used them yet.
LinkBack URL
About LinkBacks
