Page 12 of 46 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 452
Thread: Quest for 800x480
  1. #111
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by fasternfaster
    Nvidia gf4 mx440 pci card works too!!! i installed into my m10000 and display #3 was the vga out, i just had to type in 800x480 and voila! and best of all its only 33 bux shipped to my door! woot! check on pricewatch
    Can you post some more details about your setup. Can you tell what exact card you bought and if you did any particular timing settings to get it to display correctly. Also does your lilliput report 800x480?
  2. #112
    Jan 2004
    California
    Quote Originally Posted by redmage
    I did it a MSI MX4000-T128 ( Nvidia Geforce4 chipset ) that cost only 39.99 + tax at a local computer store without third-party software ( Powerstrip ) via the NView applet.
    Is their any chance you know somebody with a lilliput and you could test it out? You gave the most complete review and i will get that exact card but i am curious if it will display correctly on the lilliput.
  3. #113
    Nov 2004
    @RedMage
    what driver or applet did you use to set these settings? Did you use MSI drivers, or Nvidia drivers? Was this applet you used supplied by MSI or can every owner of a MX4000 card do the same thing you did?
    Could you maybe post some pics of this applet?
    thanx!!
  4. #114
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    all nivida cards can do 800x480 even my onboard GPU
    CarPC status: iPod, 3,456,217 songs so **** you
  5. #115
    VENDOR - SpatialMinds millec's Avatar
    Dec 2002
    Mt. Vernon, WA
    Quote Originally Posted by Lazaru5
    @RedMage
    thanx!!
    He is using Powerstrip. You can find it via google.
  6. #116
    Res Master
    Quote Originally Posted by millec
    hehe, I'm not using powerstrip. That's why I was so intent on using Nvidia because they provide such functionality. The Nvidia applet is provided with all relatively recent Nvidia GPU's or IGP's. Go to Display Properties -> Settings -> Advanced -> Choose the GeForce or whatever Tab. You may, however, have to update your drivers. Only the newer versions of the Nvidia drivers add support for custom resolutions.
    From the same dialog as above there should be a "Nvidia on the Internet" button, click and continue to download the current drivers. After there there should be a "Custom Resolution" section in the applet.
    BIOSTAR M7NCG400 : AMD-M ATHLON XP 2400+ : VANTEC AIRFLOW : 512 MB 3200 RAM : XENARC 700TSVB : MSI 128MB DDR MX4000 : MONSTER 300 WATT INVERTER
  7. #117
    Aug 2004
    I have it working with powerstrip but would prefer the nvidia software!! Only problem is I can add custom resolutions, but the advanced timings button greys out on any custom res.!!!
    Any ideas???
  8. #118
    Jan 2004
    California
    So anyone with a lilliput and an Nvidia card got everything work including having the lilliput osd display 800x480
  9. #119
    Newbie Camryputer's Avatar
    May 2004
    Michigan
    I have a M6K and a Xenarc. Instead of fighting the system and adding a video card, I just set the resolution to 640x480 @ 60Hz. It looks great. The scaler inside the display does all the work.
    Some benefits:
    1) Performance: lower source resolution means the internal video frame buffer is smaller which translates to fewer pixels for the CPU to draw.
    2) Font sizes: You don't have to select "extra large fonts" for things to be readable.
  10. #120
    Nov 2004
    I needed the newest drivers. I found them and installed them. I copied your settings (weird way of entering them though, I had to type in the numbers backwards?!?) and it works!! Nice clear screen!
    Sorry antimatter, I only have a Xenarc, so again no step further for you
  1. The quest for no noise
    By mp31500 in forum General Hardware Discussion
    Last Post: 04-02-2007, 11:12 PM
  2. Carputer Start-Up Quest.
    By thepogcbr900rr in forum Newbie
    Last Post: 06-02-2004, 12:57 AM
  3. WTB: Quest for Glory Anthology
    By naevity in forum Classified Archive
    Last Post: 02-03-2003, 01:01 PM
  4. The Quest For A New Avatar
    By Aaron Cake in forum Off Topic
    Last Post: 10-05-2002, 08:29 PM
  5. The quest for serial comms!
    By Bj in forum General Hardware Discussion
    Last Post: 12-04-2001, 09:22 PM
