Keep us updated, as I am thinking of doing the same thing...
Joachim
after searching through the whole forum and having a go myself,
finally gave up and concede to the fact that onboard video JUST can't do 800X480
finally resorted to using a PCI video card, which, is HARD to come by. PCI express may be, PCI is hard to find (just like usb gameport. "Game port? who uses game port nowadays)
i was lucky to have a PCI extension board lying around. but you first have to change the heatsink on the board to something shorter.
the card i managed to find is Inno3d's MX440 based. the driver allows you to define custom output resolution.
now in the process of installing. will post when i manage to get it to work
CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
Joachim
by the way
i sent an email to VIA to suggest more flexible resolution in the future.
kao
Good luck! I can't get 800x480 to work on my ATi 9600. Even with the utilitiy to change the refresh rate my Xenarc won't display it correctly.
89 Mustang (Autox, road race, and cruiser)
93 Escort (Daily Driver)
84 Dolphin RV (Soon to be Carputer Heaven)
ive got onboard Geforce 4 MX and ive got it runing at 848 x 480, works fine.
CarPC status: iPod, 3,456,217 songs so **** you
dudeOriginally Posted by Motoko
read the subject line. i am trying to get 800x480.
why? you might ask?
coz it's the native resolution.
i can get 848x480 on the onboard video too, so can just about everyone else.
kao
I don't get it.Originally Posted by ptk
Me neither![]()
I'm trying to get 800x480 working using a PCI Radeon 9200 card and the 7" Lilliput.
I'm using a flexible PCI-riser (I had to extend the flex-cables) and cut a small part off the gfx board using a dremel (I actually cut off a piece of the VGA connector)to get it to fit inside my custom 1-din enclosure. I also had to cut of off about one centimeter of the stock Epia TC boards heatsink.
I have not yet managed to get the exact timings for the horizontal-pane (800 pixels) so the image still lookes a little "jaggy". But the vertical is ok.
800x480x70Hz or 800x480x75Hz seems to get me the best picture on my Lilliput using the Radeion, since 60Hz looks like crap.
Some pictures:
The "low-profile" heatsink
The extended riser:
EBFoxbat, antimatter
Okie, here's my situation (and for others who use the same hardware setup)
I am using a VIA EPIA TC-10000. It has onboard video which is base on S3 chipset. It outputs standard resolutions, ie 640x480, 800x600, 1024x768 ect.....
note that these are 4:3 aspect ratio (ie horizontal:vertical)
if you are using this board on standard VGA display, all's danty and fine.
However, for those of us using 7inch touchscreen panel from Xenac/Gain/Lilliput, it spells trouble. If u have notice, those panels are wide format, and to make it worse, it's not the more common 16:9 format which some of u assumed it to be (848x480 = 16:9). It turns out that the panel has native resolution of 800X480 (5:3).
And this is not support by the onboard video.
Some might ask why not just leave it at 848x480? it's not that far apart? it's 16:9 compare to 15:9. the fact is, it does matter. Circles ain't circles, and text don't look right (coz it's not dot for dot).
The direct alternative is to use 1280x768 (5:3). In this case, the aspect ratio issue is resolved, BUT not the text. U can barely make out your text.
Hence the quest.
kao
ps. if you think aspect ratio for PC monitors are confusing, wait till you work with video ON PC.
