Results 1 to 9 of 9
Thread: my 7 1nch screen
    my 7 1nch screen
    hi i planing a carpc but i cant buy the liliput (cost to much). so im looking at this one http://cgi.ebay.com/ws/eBayISAPI.dll...723285202&rd=1 . my question is how do i connect this to my car pc?.....ty
    Mar 2004
    Vancouver, BC, Canada
    You need something in your computer that can do S-Video out.
    Be warned that S-Video is lower quality than VGA.
    is this my only option?. and if so is it a huge difference?. also do u have a link to the s-video thing so i can see the price of it?...ty
    Elsewhere
    Quote Originally Posted by lasteclispe
    You need something like this.
    The other option is a graphics card that has S-Video out. There's dozens of brands/models out there with this capability, so find one that meets your requirements and budget limitations.
    And in my opinion, it's a huge difference.
    RCA composite & S-Video are designed for TV/video signals, which are a lower resolution/refresh rate than a computer's SVGA output.
    I've seen the S-video out to a TV and it really does look crappy.
    Oh, and that product was found in about 30sec with a broadband connection and . USE IT!
    How about the Wiki?
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    and to spoil the party a little bit more, I dont think that monitor / screen conforms to a DIN standard so it might not fit in your dash with a simple bondo "job" if they can ever be simple, you see that screen is 7.2 and the Xenarc / lili that is favoured is a 7 inch and, and, and so please measure up your space properly first off.
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FS = MTSVO motorised in dash screen pm me for details
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    Quote Originally Posted by SAScooby
    Im not sure but i thiought the dimensions of the lill and xenarc screens where 7.2" could be wrong
    that screen is composite / svid, gonna look really crappy on a vga signal
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    DarquePervert:
    Just FYI that cable is not a VGA->composite/s-video converter cable. Do not plug that into any VGA card expecting it to work. I believe those types of cables came with the Matrox G200, G400, and G450 series cards -- They output NTSC and S-Video on the VGA connector and the cable simply gives you the correct plugs. It is similar to DVI->VGA cables in that the analog signal itself is output from the DVI connector, but the plug is not compatible with standard VGA monitor plugs.
    A real scan converter to convert VGA to NTSC is quite a bit more expensive. You can find them as cheap as $60 or so on ebay.
    Here is a page with a lot more information about VGA <-> TV conversion.
    BTW the difference in picture quality is no contest. While NTSC (Television) video is technically capable of 720x480 resolution, putting the signal onto an S-Video or Composite transport is going to really make it blur. Plus most of the TV encoders on video cards are very cheap, so they compound the blur problem. Finally, the signal is interlaced meaning that you only get a maximum of 720x240 resolution every field.
    Go with a VGA monitor. Now that the VGA option has been available for years in the 7" form factor, people should not even be asking this question any more.
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
    Feb 2004
    Okay here is a picture of a liliput VGA 7 inch LCD (thanks to digitallww for the image) as you can see it is smaller than a 7.2 inch screen.
    Get a better screen and save money on processor / mobo etc, the screen will be with you for a long time and its the way everyone will see your new toy, skimp on the screen and you wont enjoy your system as much
    Nov 2003
    Olympia, WA
    These guys are right. Save your money for a vga screen. I speak from experience. I have a a non-vga screen and it's okay but I'm getting a vga screen this week.
  1. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  2. What the....same screen? Good screen?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-31-2004, 12:37 AM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  4. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
  5. Laptop/LCD screen hookup...
    By UrbanTacticz in forum LCD/Display
    Last Post: 11-28-2001, 06:49 PM
