Mine would do it when I had the refresh rate over 75. Maybe look into that.
Does anyone else have the problem with their Lilliput where it flickers on and off as if it was Auto-Tuning all the time? I don't get it. It happens randomly and it has nothing to do with the connector because I cut the DIN and soldered the wires together to ensure a solid connection and it had no effect. I hate this screen!
I have mine set to 85Hz.. interesting idea. What do you set it to? When I set it lower, the screen has a "roll" in it similar to when you see a computer monitor during a TV show.
This might be a long shot... Mine is installed into the dash where the heater vents used to be. When the heat is directed to the windscreen it also vents to the rear of my screen. after a short period I start to get flickering. If I turn the heating system to cool or put on the air-con, everything returns to normal i.e. no flickering effect.
Hot circuits = flickering
Cool circuits = normal
I set mine to 75, and it went away. What is weird is usually you do the opposite to get rid of flicker...set it as high as the card can go. I'm going on 2 or 3 weeks now with no flicker. I never minded during the day, but at night it would drive me nuts.
