Results 1 to 5 of 5
Thread: Xenarc Hardware question
    Oct 2004
    Milwaukee, WI
    I have ed and found two schools of though for hardwiring a Xenarc 700TSV.
    1.) Cut of the cig adapter and splice it in to the cig outlet power cable, w/ an inline fuse (1.5W?) This would mean unregulated power, but some have mentioned that the Xenarc can handle that.
    2.) The cig adapter has a regulater built in, so don't remove that from the source of power. Somehow do the same as above, but keep the built in regulater inline.
    Can anyone clarify which one is better?
    Aug 1999
    Washington D.C.
    1 is correct. It accepts unregulated power, but don’t forget the inline fuse.
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    You could also look at the 3rd school of thought and look at wiring to the 12V+ of the PSU
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    The cig adapter doesn't have a regulator built in. I opened one up some days ago.
    Mine is connected to a ignition wire, but I will connect it to the 12v rail of my opus, so it will shut off when the computer does (and and stays on if the computer is running, even with ignition off).
    The fuse should be 1.5 A and not W.
    Joa
    Oct 2004
    Milwaukee, WI
    Ok, great. I intend to eventually hook it up the the computers, PSU or an opus, but I am doing a sort of "proof of concept" to see how the XENARC looks in my dash. I will be using my laptop for the first few weeks...
    Thanks for the help.
  1. question about hardware for ODB-II
    By RogerWilco in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-22-2007, 09:17 PM
  2. Question: Xenarc w/ts and screen saver
    By Tony S in forum LCD/Display
    Last Post: 04-06-2004, 04:16 PM
  3. Question about the Xenarc 700TS
    By Raekwon in forum LCD/Display
    Last Post: 02-27-2004, 04:26 PM
  4. Xenarc 700TSV USB question
    By paulpv in forum LCD/Display
    Last Post: 09-28-2003, 02:32 PM
  5. Xenarc, installation question..
    By Mtlca401 in forum LCD/Display
    Last Post: 05-15-2003, 12:09 AM
