If it has a suitable power input (basically a dc input around 12v so you dont need a transformer) then it should be pretty easy... You just might want to mount it somewhere where it blends in, cause 15in is pretty big for a car, it is easy for it to take up a lot of room...
Other than that I dont see a problem as long as you can have a dual head card or something like that (I'm not sure how Y-VGA cables work, and also you probably want a different resolution on the 15in and on the lilli').. I'm also unsure how windows will handle having 2 displays showing the same thing at different resolutions - although it might not be a problem at all...
I'm also unsure how it is possible to have different outputs using one of the common frontends... like having the menu on the lilli and video/visuals only on the 15in... dunno, but I really dont see a problem with the 15in...
LinkBack URL
About LinkBacks
