Results 11 to 20 of 24
Thread: got new lilliput but problems.....
  1. #11
    bakersfield, ca
    you try try installing the drivers manually? This is what i had to do, go to device manager and look for the yellow exclamation mark, this should be the touch device, then try to update drivers, and have windows do it automatically, that should work, if not try to show windows the diver folder manually and that should work. That worked for me.
  2. #12
    Quote Originally Posted by mp3oplecarrier
    Surely you should be connecting power, vga and usb for the touchscreen?
    What is the PS2 attached to?
    Steve
    ok, first off.....sorry guys, for some reason i wasnt thinking straight and thought i was using ps2, but i was using USB (and vga) the whole time.
    Now...on to progress. I was fiddling around and uninstalled all drivers and reinstalled the newest drivers.......well, when i restarted i finally got everything to show up on the lilliput. However, the touchscreen isnt working. Windows tells me "USB device found: touchkit controller" (even though i just installed the touchkit drivers?)....i'm asking you guys what i should do from here because i don't want to screw anything up and lose video again.
  3. #13
    Jun 2004
    Central California
    Lilliput with touchscreen uses USB which then converts to COM. It's not PS/2. Leave it unchecked.
    The PS/2 look alike port is just a connection Lilliput's manufacturer decided to use. It actually serves both the VGA and USB connections.
  4. #14
    Quote Originally Posted by edikp
    yeah, when i reinstalled the drivers i left the ps2 unchecked.
    Now, here's some desktop screens to maybe help someone help me?
    first picture is device manager telling me device isn't working (i disabled the modem to free up comm3 incase).......notice on the bottom the touchscreen is already installed so it SHOULD be working?
    second picture is device manager telling me it isnt working because it isnt configured properly?
    third picture is the options it gives me when i choose "update drivers" in device manager.......i havent chose either of them to use as an update yet though.
    Also, i don't know if it matters but i have neither SP1 or SP2 installed on xp
    edit- have to work now, will come back and fiddle with it more, please keep up with suggestions
  5. #15
    bakersfield, ca
    just update with either one, one is the original drivers that were on the little cd, and the other one is the updated drivers. Just try one, if it doesnt work try the other one.
  6. #16
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    im having the same problem right now,, i had an old one it got fried i sent it back then i get the new one.... and its not working,, im gonna try and manually install the drivers tommorrow.. but most likely ill get out of bed tonight as itll drive me crazy and try
    throw a moon
    heuvos vin chevos
  7. #17
    Aug 2004
    tx, USA
    when i unplug and replug the USB connector from the screen to the USB hub it doesnt even get recognized.. i had the exact same setup on my old Lilli.
    I had 2 ideas
    Maybe the 9 pin connector wasnt gettin a snug connection,, as its harder than my old one,, but the screen comes on and works so i highly doubted that.
    Second was maybe this was a new Lilli and it wouldnt recognize the touchpad without the new drivers.. so ill try those now and see what happens.
    hoping anyone else has any other ideas
    throw a moon
    heuvos vin chevos
  8. #18
    Aug 2004
    tx, USA
    do they make the same lilli's with no touchscreen? this one does look exactly like the other,,.
    I should have edited the previous i know.. oops.
    :edit: the USB controller is NOT showing up under device manager at all regardless of what i install reinstall uninstall. and its on the EXACT same setup as the previous lilli
    throw a moon
    heuvos vin chevos
  9. #19
    V50
    V50 is offline
    Newbie V50's Avatar
    Lisboa, Portugal
    Install SP1 on windows cause it solves a lot of USB problems
  10. #20
    Aug 2004
    tx, USA
    Quote Originally Posted by V50
    if your talking to me i had it working prior to this screen with my old lilliput
    :edit: took my pc out there and still nothing,, goddamn lillis
    throw a moon
    heuvos vin chevos
  1. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  2. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
  3. HELP I got lilliput problems
    By Dluvr22 in forum LCD/Display
    Last Post: 05-22-2004, 12:29 AM
  4. Lilliput problems (yet some more)
    By samc in forum LCD/Display
    Last Post: 05-06-2004, 10:51 AM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
