Results 1 to 10 of 11
Thread: Best monitor for Double Din?
    Constant Bitrate sanbas's Avatar
    Jul 2004
    united states
    I am trying to figure out which monitor would be the best fit on my dash. If the LCD is too big for my double din then i dont mind taking the casing out and somehow using the LCD only for mounting if possible.
    Options so far include:
    Lilliput 7" Touchscreen:
    Pros:
    1. alot of people are using so it cant be bad...also lots of complaints though
    2, remote included to adjust screen (this is important if i take casing off)
    Cons:
    1. the case outside edges arent straight, bottom is rounded. Wouldnt look good on my dash with the case and buttons.
    2. Case color is isnt black
    3. alot of people are reporting problem with their lillys
    4. $279.99
    Xenarc 7" Touchscreen
    Pros:
    1. Has square edges if i decided to use the casing and its black.
    2. Although not used as widely (b/c of $$$) the reviews are all GOOD
    Cons:
    1: $399.99...cost more than my 17" LCD!!!
    2. no remote
    3. no tutorials on how to disassemble LCD from case
    4. want to stay away from b/c of price unless you guys with experience say i will be disappointed with the lilliput or others.
    SP7 or starvision touchscreen
    Pros:
    1. $249.99 (cheapest of the 3)
    2. Square edge
    3. Remote included
    4. Black Casing
    Cons:
    1. Probably not good a quality, esp. when sun is out
    From the 3 i only have dimensions for the Lilly (from "searching") and it is too big with the case on for the double din and too small without the case.
    Any of you guys that have installed a LCD into your dash have any idea or PICTURES AVAILABLE???
    Here is the picture of where i want to mount the LCD...I think i want it permenantly there and not be easily removable, not worried about being broken into yet
    thanks for looking!!!
    Constant Bitrate CustomZ02's Avatar
    Austin, TX
    I used a lilliput 7inch on my double din. I just cut off the bottom part where the buttons were and it fit like a charm. So glassing and bondo makes it look nearly stock. Heres a pic of how mine turned out. And I havent had a problem with my lilli yet. Cept for when I installed it wouldnt power up but that was due to some dirty connections with all the dust I had.
    Starting new project. After some jackass broke in and stole my screen.
    Jul 2004
    united states
    oh thanks that helps alot!!!
    my sister has a civic with the exact same interior...ill take a look at hers so i can get a before and after of the work u did.
    Austin, TX
    No problem
    Constant Bitrate heypachuco's Avatar
    Mar 2004
    USA
    Lilliput makes some of the Starvision monitors.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by sanbas
    Pros:
    Cons:
    4. $279.99
    Can't speak for the others (although without casing I think they will all fit) but the Lilliput does fit without case.
    www.carTFT.com do a black one.
    I've had two my first was of ebay guy from hong kong, dodgy from start and has all but died, but it did go through a lot of taking apart and putting back together again while I was designing/building dash mount
    my second is from above and so far (touch wood has been fine).
    They have made some changes and I think the quality has improved.
    Mar 2004
    Speaking of carTFT.com, here's a comparison chart that also lists the dimensions...
    http://www.cartft.com/carpc/catalog/il/382
    Jul 2004
    united states
    man thanks that page is very helpful!
    been reading a few more threads about lilly vs xenarc...I really feel like buying the lilly would be regreful down the line. I am just going to hold my breath and buy the xenarc probably, but its gonna be hard to spend that much money on a 7" monitor.
    This carPC project keeps getting more and more expensive!
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    dude no ****,, i thikn regardless wherever you buy your LILLIPUTO, its gonna be the same quality,, i have had 2 of the newer ones in the last 7 weeks ( i have *****ed about this in about 5 threads now) but i cant get over how weak it is,, i mean 2 screens,, both bull****,, the odds are def against you if you buy a Lilli,, im thiknin of trying thr sp7,, its just insane to throw 400 for a screen out there.. INSANE
    throw a moon
    heuvos vin chevos
    Nov 2006
    Quote Originally Posted by CustomZ02 View Post
    That's why my ideal screen would be DEATACHABLE (very important where I live).
    So just a detachable screen with inputs. All other electronics reside in the (hidden) car-puter and amplifier. I guess a button interface around the screen would be cool, and enough space behind for a slot-load, slim optical drive.
    When (and if) all that's available I'll make the switch from a head unit/hard drive setup.
  1. 1 DIN, 1.5 DIN, 2 DIN, what's a guy to do?
    By Chairboy in forum LCD/Display
    Last Post: 12-27-2010, 02:50 PM
  2. DIN and Double DIN Dimensions/Standards
    By kubark42 in forum General Hardware Discussion
    Last Post: 08-05-2009, 02:39 PM
  3. double din adaptor? 2 1-din devices in a double din space possible?
    By ucidave in forum General Hardware Discussion
    Last Post: 09-17-2004, 06:10 PM
  4. anyone know how many DIN a 1998 jeep grand cherokee laredo is?
    By Nav_Attack in forum General MP3Car Discussion
    Last Post: 09-08-2004, 07:12 PM
  5. Help me understand PC in a DIN chassis
    By cproaudio in forum General Hardware Discussion
    Last Post: 06-11-2003, 11:51 AM
