Results 1 to 4 of 4
Thread: 8" Lilliput adds noise to my stereo
    When my LCD is turned on I get noise through my FM stereo.
    I have an FM modulator, but even with the modulator turned off I get noise if the LCD is turned on. When I run the sound through my computer it is worse.
    I have also noticed it gets really bad when my wireless PCMCIA card is plugged into the laptop.
    Has anyone else had this problem?
    How can it be solved.
    I have the factory radio in an '04 Malibu Maxx, the modulator is connected to the fuse box. The Lilliput is connected to the cig plug using the supplied Lilliput cable w/ egg thing.
    The computer is connected to the same power fuse as the modulator using a car laptop power adapter.
    Waterbury, CT
    I have the 8" powered directly from my ITPS without any noise. I have my screen directly under my radio too, so while I don't have a solution, I can tell you should be able to fix it.
    Maximum Bitrate DeltaFX's Avatar
    Sounds like a grounding problem...
    Variable Bitrate euro320i's Avatar
    Apr 2003
    Near Frankfurt
    A lot of installs in this forum use 12vlts from the DC-DC converter.. mostly it is because the grounds are taken from different point on the chassis - in your case sounds like you have a ground off the ciggy..change the ground - prefferably to a common one. good luck
    '94 320i
  1. Lilliput egg noise, solutions?
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-24-2004, 01:24 AM
  2. Noise in Lilliput from HDD
    By zvi in forum LCD/Display
    Last Post: 07-14-2004, 12:17 PM
  3. Replies: 9
    Last Post: 06-22-2004, 01:24 PM
  4. Lilliput causing engin noise
    By eazyrog in forum LCD/Display
    Last Post: 06-07-2004, 08:58 AM
  5. Lilliput 8" Touchscreen Display
    By Randomtask in forum LCD/Display
    Last Post: 02-06-2004, 01:12 PM
