Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: cannot get lilli touch to work anymore
  1. #11
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Forget checking that information, check these things:
    Does your computer recognize the touchscreen. i.e. in the system/hardware/usb do you see the touchscreen show up when yo unplug or plug it in. Usually winxp gives some kind of ballon notification in the taskbar.
    Make sure your Cable doesn't have a bent pin. <-- CHECK THIS. This is what i think your problem is. If not your USB controller could be bad, thats why i asked if Windows recognizes it.
  2. #12
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    Quote Originally Posted by antimatter
    yes check this for sure,,, as my current replacement DOES not recognize the LIlli when i plug it in. And after moving around the cable for a little bit the hardware wizard popped up but failed as i was moving the cable around. I was going to cut the wire and resolder it but they are sending me another..for free.
    throw a moon
    heuvos vin chevos
  3. #13
    Jan 2004
    California
    @Pacman
    Your problem is probably a bent pin. Have you looked at the pins from the DIN cable that comes out of the lilliput. Are they all straight?
    I had this problem. after replacing the touchpannel, and usb controller i found out it was a freekin bent pin
  1. IBM 4820 touch screen
    By lez in forum LCD/Display
    Last Post: 12-16-2007, 07:23 AM
  2. IPOD round touch thingy
    By awh4992 in forum Input Devices
    Last Post: 08-03-2004, 07:06 PM
  3. help, my head unit doesnt work anymore
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 02-01-2004, 04:13 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Replies: 4
    Last Post: 11-18-2002, 09:59 PM
