you do realise why its so bright dont you?
Just got done with installing my new system 2comp vr12's spl amp,Cap,Video amp, and 2 Headrest tvs. so i had my whole car a part from inside today and i figure that i can do some testing on what is the best way to power lilliput. I found that to completely get rid of flickering either hook it up right to the battery, or the Computer power supply. Next thing i did was hooked it up to the wire hardness or where the cd player up front. It flicker really bad. Next i hooked it up to the distribution block where my amp wire plugins in. It was really bright and very little flicker very hard to notice. All this people saying to hook it up to the PSU, I think its garbage. It is almost twice as bright when i hooked it up to my distribution block. I had my indash lilliput hooked up to the psu for two days. when the sun hits the screen its not readable at all,but today when i had it hooked up to my distribution block it wasnt the best,but i could still read the name of the songs. Hope this helps all the newbies that keep asking how to power lilliput.![]()
Signature: [==||========] 20% complete
Does it have the egg, or is it eggless??? If it is eggless, then it is getting 13.7 or so volts, and it will eventually fry
Carputer currently 'ghettoed' into car!!!
EPIA MII-12000
Ampie Case with rigged extra USB
Hitachi 60GB
Holux GPS mouse with iGuidance 2.0
Lilliput 7" touchscreen
Netgear WG121 USB WiFi
Carnetix P1260
this is what i got http://www.digitalww.com/DWW-7VGT.htm now i am wondring if i should add the egg to it?
someone please respond. I just want to know if to hook up the egg. will i be fine hooking up to the distribution if i use the Egg that comes with the lilliput? sorry just want to know before i buy the egg.
The "egg" is a regulator (and a poor one at that)
Unless you want to fry it, hook it up to the regulated output of your power supply. It'll be slightly dimmer, but it will last a hell of a lot longer.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Just to add something to this, I've had 2 7" Lilliputs do the funky touchscreen thing on the right hand side. The first was fine when used indoors on the mains power but screwed up when I got it in the car. When I got the second one I kept the egg from my first one as I had hard-wired it. Five minutes after I plugged in & switched on the touchscreen was screwed.
Could it be that a bad egg has killed these screens?
Rob.
if one runs a voltage regulator on the PC power supply, wouldnt it be best to wire screen into the copmuter power output? just asking here as i am looking to start installing my setup within the next week or so...i will be running an AMD Athlon XP on a micro ITX, 512MB DDR, and an 8" lilli touch...i will be using a PW-70 and an ITPS...should i just run the screen power to the power supply or should i use the power that i had used for my current stereo?
thanks...Mario
If you overdrive the back light inverter (which is the only way to make it brighter as you claim to have) you will burn the backlight out in potentially as little as a month.
