What worked for me in getting the brightest screen was to cut off the egg and use the ac power adapter that came with the lili and plugged it into a converter. If you're using the opus then run it off of the 12 volts from the molex connector.
Before I switched cases and power supplies I use to run it from the 12 volts from the molex but when I got a new case and power supply I got some intereference so I just used the ac adapter because the inverter was right there.
- Kyle
LinkBack URL
About LinkBacks
but couldn't find what I was looking for.
