Results 1 to 10 of 18
Thread: Can the PSone lcd be used with XBox once its VGA modded?
    Newbie xboxerxbox's Avatar
    Oct 2004
    Im about to recieve my PSone lcd screen and I read around and found the VGA mod. I was wondering if I bought an Xbox Vga adapter, would the PSone lcd work with it? Or can I solder directly to the Xbox scart connections without turning it into a VGA.
    Dec 2003
    wait, i thought the xbox used composite or svideo connection?
    Constant Bitrate Malenko's Avatar
    Jul 2004
    Newark,De
    hit the tutorials on www.xbox-scene.com. you can pull the signal from the XBOX mobo if you want
    Oct 2004
    I know the XBox has composite and S-Video. But i was wondering if the PSOne lcd would work as the PSone lcd works only at 15MHz or something. But if theres not too much of a quality difference Ill just pull the connectioins from the SCART from the mobo directly. And Yes I know about XBox-Scene (been there since 2001 ). I know the scart connections for the Hip Pad mod but the lcd is next to unusable and anything besides the coolness factor and since I am getting the PSone lcd dor $25 I thought "Why not go with this then?"
    Edit: I also have the S-Video pack for the XBox which has RCA outputs. I can just buy the RCA to 3.5mm pin and use that too right?
    Oct 2004
    Alse here is the XBox's scart video and sound connections. If i use the 3.5mm cable and solder the stuff to the connections will it be OK?
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    I don't think the xbox can do the 15khz horizontal refresh that the psone display needs. Just use the composite input on the PSOne display.
    Oct 2004
    Yes that diagram is for the compsite display. And starfox can I use the PSone LCD with the EPIA M Series motherboards in anyway?
    May 2002
    Australia
    I don't know for sure, i don't have an EPIA M motherboard. I suspect not as i haven't seen anyone report success with the mod.
    Oct 2004
    O well. I might just go with compsite connection with the XBox and flush mount it on the top. This is going to be my first (cosmetic) mod project.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    It can't be used VGA with an XBOX. It also can't be used on an EPIA mobo with Windows, though I've seen it work with Linux and uhh... xfree86 I think...
    Tidder
    Try RevFE
  1. PS1 LCD VGA mod Summary...
    By odin836 in forum LCD/Display
    Last Post: 01-13-2007, 07:16 AM
  2. flip down VGA LCD?
    By SirCyRo in forum LCD/Display
    Last Post: 09-18-2006, 07:14 AM
  3. Modded Xbox for sell (to help mp3car community)
    By darkhalo in forum Classified Archive
    Last Post: 03-30-2005, 04:40 PM
  4. VGA LCD Monitors Vs. Standard LCD Monitors
    By yrga in forum LCD/Display
    Last Post: 09-27-2003, 11:34 AM
  5. VGA LCD or TFT LCD???
    By TruamaDoc in forum LCD/Display
    Last Post: 05-09-2002, 12:43 AM
