Results 1 to 5 of 5
Thread: text on flip down 12.1" lcd
    Low Bitrate odleon's Avatar
    Atlanta
    does anyone have experiance with flip down 12" lcd's?? how is the text? i know that video will be good, but is it like the 6"-7" lcd as far as text(blurry)??
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    what signal type are you talking abou? if its VGA you'll be fine...
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
    Atlanta
    im talking bout the regular rca flip downs. i thought, since its bigger, it might not have the same prob as regular, non vga 7" lcds(blurryness).
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    It'll be worse....dont do it. Xenarc has a nice flip down 7" VGA.
    May 2004
    Denver
    the problem with text is that your source needs to be mapping the signal on a pixel to pixel ratio... so if you run 800x600 on a xenarc or lilliput 7" you can expect horrible quality, but if you scale back the resolution to the true 800x480 you will not believe your eyes...
    this is true on high def televisions too, a 480p signal looks great on a 480p screen (technically called "Enhanced Def")... and that same signal is actually degraded when shown on a 720p screen, because the screen is forced to interpolate the data, which was already done once by the video source...
    so point being if you want sharp text on your large screen, just run the source in the screens native resolution and your text will look it's best...
  1. flip down VGA LCD?
    By SirCyRo in forum LCD/Display
    Last Post: 09-18-2006, 06:14 AM
  2. DOS C++ Program: How to output text to a 40x4 LCD
    By bombboyer in forum Software & Software Development
    Last Post: 07-18-2005, 07:33 PM
  3. Replies: 6
    Last Post: 05-21-2004, 12:01 AM
  4. FS: IBM 12.1" LCD
    By Shaar in forum Classified Archive
    Last Post: 02-17-2004, 03:50 PM
  5. Hooking up a 12.1" Laptop LCD
    By Griff1324 in forum LCD/Display
    Last Post: 11-16-2001, 06:03 PM
