Results 1 to 10 of 12
Thread: Lilliput Touchscreen Calibration - WORKED FINE - Then....
    Oct 2004
    Bay Area, CA
    I got my 7" Lilliput on Tuesday. I have been playing with it for a few days now, but as of last night the touchscreen has been off. I Re-Calibrated it, and it does not help. When I touch about half way up, the mouse goes way out to the left. I used the drawing tool to show you this. I tried the 4 point calibration, then the 25 point calibration, and then I cleared it off and tried it that way.. NOTHING WORKED! What is causing the touchpad to just go screwy like this? I thought it might have been the heat from the screen being on, but I've let it cool down overnight and its still this way! HEEELLPPPP!! I want to install it but I can't if it's not working right!
    I did the items in order as they are posted below.
    See Attached Pix:
    Oct 2004
    Bay Area, CA
    Also - I should add this is so I don't have to start a new thread...
    I am using Frodoplayer, but when I set my screen to 800x600 resolution, frodoplayer loads at the same position as when at 1024x768. It shows up at about 1/2 down the screen. Ideas?
    See Pix:
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    I had the same exact problem, Lilliputs are crap for sure... check it out...
    HERE:
    What could be the problem with my Lilli?
    I don't have the pic anymore, your touchscreen "came apart", mine did too. I ordered a direct replacement From Armen, and now it works.. Bad news: no way to repair, only exchangable...
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    Quote Originally Posted by Mrbmw99
    See Pix:
    In frodo.ini change ur settings to this
    [ADVANCED]
    ADV_TOP=0
    ADV_LEFT=0
    ADV_WIDTH=800
    ADV_HEIGHT=600
    [|||||-----] 95% complete
    Jan 2003
    Overseas
    Definately a bad touchscreen, the same happened to me and other people as well. I just sucked up the price and bought a Xenarc.
    Squigg
    2002 Mustang GT
    xp2200,80gig,GF4MX4400,512ram,7inVGA Touchscreen, Side View Camera w/sound, USB GPS Mouse(computer hidden in LH Rear QP)
    Super Moderator xBrady's Avatar
    USA
    See Pix:
    Go into settings 1, then go to misc1 and uncheck the use advanced settings option. No need to mess with the .ini file as was posted above.
    Installed.
    -GPSSecure- - GPS Tracking
    Oct 2004
    Bay Area, CA
    I already changed the ini and all is good.... Thanks!
    Oct 2004
    Sweden
    I have the exact same problem, on THREE lillis...
    Have anyone got this error with the Xenarc monitors? I thought they were using the same manufacture of touchscreens...
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I had mine for a couple months and it worked great.. No problems.. But in the past couple weeks I've experienced problems similar to yours... Say I'm in FrodoPlayer and I go to touch the "next" arrow.. It goes no where near it. Then I'll try and hit menu or something and it won't be anywhere near it again..
    The one time I was hitting all the way over by the clock in the systray and it was clicking on an icon right above the start menu.
    I can recalibrate and hit all 25 points dead on.. It will then work for about 10-15 minutes and then get jacked up again. I'm still trying to figure out whats up with it.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Jul 2004
    Indialantic, Fl
    Yes I had this problem and ordered a new touchscreen and controller. Later I found out that the old one actually isn't bad at all but I just needed to reinstall the drivers. Try that before you go getting new parts.
  1. No Signal on Lilliput 7 Inch touchscreen.
    By SuperDave01 in forum LCD/Display
    Last Post: 05-04-2008, 10:36 AM
  2. Replies: 4
    Last Post: 10-13-2004, 10:17 AM
  3. FS: 7" Lilliput LCD w/ touchscreen
    By sohr in forum Classified Archive
    Last Post: 08-25-2004, 05:59 PM
  4. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  5. Trouble dragging on Lilliput touchscreen
    By archimense in forum Input Devices
    Last Post: 05-06-2004, 09:04 PM
