Okay,
I think I worked it out, after having a good read through the gamesx.com site I found the pinout details that I needed to workout what wires where.
For anyone who has a Wild Things PSone monitor, please follow this guide:
1. goto
gamesx.com Playstation A/V Pinouts
follow the two pics and workout what the pin arrangements are, on a Wild Things board its easier to work out the pin arrangements if you look at the image of the AV MULTI OUT connector (second image on right) and then get your Wild Things
power board and look at the AV MULTI OUT connector.
You will see that the plastic connector is surface mounted and on the back has legs going through the board (soldered on the other side) - you will notice that the pin arrangement is inverted compared to the guide provided by Starfox, thats because the Sony version is not mounted in the same fashion as the Wild Things connector.
If you look at the guide on gamesx.com and then follow each leg to its soldered point you will workout which pin is what.
2. Below is a diagram I put together of the pin arrangement for the Wild Things version of the PSOne monitor:
Sorry for the crap quality but I have marked the pin arrangement for clarity, anyone with one of these monitors should be able to workout what I am on about.
Here is a shot of the AV MULTI OUT connector, I have marked the arrangement of the pins for clarity.
3. Follow
M Pro's guide to wire up the the RGB VGA cable to the board.
That should be it, with any luck you should get an image, my initial image was surprisingly good if a little hazey but I have been tweaking the image via Power Strip and I found out the pots on the actual LCD front are used to control the image so a bit of tweaking here resulted in a slightly better image. I am not going to post any images just yet as I first want to workout what the correct settings are for Power Strip using an ATi Radeon, an ATi Rage Pro 128+TV OUT and a Matrox - when done (in a few days) I will post all the details so any Wild Things owners should have all the info they need to get going.
The only thing I need to do now is wire in the correct resistors to improve the RGB signal (I used a res that was near enough to what M Pro suggested).
Cheers and good luck.
Godz
