Are you trying these drivers?: http://www.egalax.com.tw/Download.htm
Armen
When ever I try to install the Lilliput drivers I get an error saying that something in the INF was invalid. It appers to only be the USBTouchScreen.inf (Or whatever, I dont remember the exact file name). Anyone had this problem before? How do you fix it?
Quick! To the Popemobile!
Armen
Yes, I was using the touchkit drivers. I am downloading the new version. Maybe this will help.
i am having this same problem on my laptop with any/all drivers listed on that site... running xp home if that makes any difference.. does any1 know the problem?
marin
Rum injected!
Car PC Status
- 7" lilliput touch mounted above rearview
- P4 2.8
- globalsat BU-353
- no software yet, but soon to be installed!
New Car PC in progress for the new car!
its all good now, found another thread stating that they thought you have to run the setup program first, then install the drivers, and presto, all good for me now.... just gota tweak the touch settings now...
marin
Rum injected!
Car PC Status
- P4 2.8
- globalsat BU-353
well, slightly more detail on how i fixed the prob on mine, have to make sure when you run the setup program before installing the driver, the touch controller is DISCONNECTED (for me this was the usb), then you connect the touch controller and it should be good.
marin
Rum injected!
Car PC Status
- P4 2.8
- globalsat BU-353
can you hit a "continue anyway" button?Originally Posted by ShaneFK
CarPC Status
[|---------] 10% Complete
Home Rig -
Athlon 64 (939) 3200+ (Watercooled)
DFI NF4 SLI-D Mobo
Gigabyte 6600 128MB PCI-E Video Card
(4) 9GB U160 SCSI HDDs in 36GB Raid 0 Array
160GB Seagate S-ATA Drive w/NCQ
Dell 20.1" Widescreen LCD
Yeah, then it crashes. After it crashes I can open the utility and search for a device but then the program says it encountered an error and closes.
