Results 1 to 10 of 11
Thread: 800 x 480 on EPIA 800!?
    _wd
    _wd is offline
    Feb 2004
    I just ordered a xenarc/lilliput clone on www.myelectronics.nl (209 euro ex 19% tax !!)
    I wanted to adjust the internal s3 vga-adaptor of my epia800 board with powerstrip to get the 800x480 resolution.
    Guess what, i just read that this is only possible with the epia1000 and up
    A solution would be a separate vga adaptor in my epia800. But it has to be PCI and with a chipset which is supported by powerstrip.
    I saw that that the same shop offered a _weird_ trident vga adaptor supporting different resolutions, has an on-board MPEG-2 decoder, PCI style and costs about 39 euros excl. 19% tax.
    look here: http://www.myelectronics.nl/contents...d=38271.490278
    Is this a good thing? I see that it supports 844x480 standard. Is this good for my lilliput screen. I now nothing about this chipset, and it's so cheap..
    What's your opinion ?
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    No VIA Epia boards do 800x480, or any custom resolution. Your best bet is a Matrox, Radeon or GeForce PCI card, as most of those allow custom resolutions.
    The other option is to just use 800x600, like many people do. It doesn't look too bad.
    The screen you have bought is a Lilliput, please don't ever call it a Xenarc again, as it isn't.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    _wd
    _wd is offline
    Feb 2004
    whoops, sorry..
    thanks for the info, but i've read that some epia1000 owners do manage to get 800x480 out of their onboard video using powerstrip like so:
    http://www.xenarc.com/faq.html#QA1
    But this can only be done with the (newer?) onboard chipset of the epia1000 and up.
    Jun 2004
    The North, Manchester
    A xenarc power strip fora lilliput monitor?? u sure?
    Aug 2003
    Essex, England
    No. It doesn't work on any VIA Epia boards.
    They cannot physically output 800x480, we as a community have been trying for WELL over a year to get this to happen, and it's not possible.
    Garry
    www.aimee.cc
    _wd
    _wd is offline
    Feb 2004
    hmmm guess you're right then..
    Did you look at the video card i linked to?, could this be a solution to the problem?
    Aug 2003
    Essex, England
    It doesn't say that it supports 800x480.
    www.aimee.cc
    Low Bitrate l0gic's Avatar
    Essex - UK
    Quote Originally Posted by _wd
    Is not having 800 x 480 actually a problem?
    I have an EPIA 800 running at 800 x 600 and it looks fine - honest
    Kevin
    Build status {..........|} 99%
    All installed - now into the fiddling about stage
    Car:MR2
    MB: EPIA C800
    Display:Xenarc 700TS
    Power:PW-70A & ITPS
    Mem:384MB
    HDD:40Gb Maxtor Diamond max
    Radio:Dlink DRU-100
    GPS:BU-303
    OS:XP SP2
    _wd
    _wd is offline
    Feb 2004
    I hope you're right. I expected the screen to arrive today. Waited for it until 15:00 h, then i went for some shopping, when i came back, i found a note from the delivery in the mailbox
    I'll pick it up tomorrow
    Essex - UK
    Well i'm running mediacar and I've also tried media engine and frodo.
    They all look and can be used fine
    Ain't it always the way. I'm sure the delivery vans sit around the corner until you leave the house......
    Kevin
    Car:MR2
    MB: EPIA C800
    Power:PW-70A & ITPS
    Mem:384MB
    Radio:Dlink DRU-100
    GPS:BU-303
    OS:XP SP2
  1. FS: VIA EPIA 800 Mobo (2.of).
    By tailormadepc in forum Classified Archive
    Last Post: 10-03-2006, 04:32 PM
  2. VIA EPIA 800 Mini-ITX Mainboard (£50 incl. Postage).
    By buildfromscratc in forum Classified Archive
    Last Post: 07-26-2004, 05:52 AM
  3. Help with Epia 800 / pw60 / ITPS
    By lalo in forum Power Supplies
    Last Post: 01-04-2004, 03:39 PM
  4. FS: EPIA 800 ITX Motherboard
    By dr1ft in forum Classified Archive
    Last Post: 08-05-2003, 09:57 AM
  5. Epia M and Epia 800 differences
    By wysiwyg in forum General Hardware Discussion
    Last Post: 12-20-2002, 11:50 PM
