Results 1 to 3 of 3
Thread: DVI -> VGA
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    DVI -> VGA
    Since I am moving my "toyputer" from under the drivers seat to under the spare wheel in the boot I was wondering since the docking station has a DVI connector would it be better to run a DVI cable from the boot to under the drivers seat then convert the DVI to VGA, then split the VGA signal and send VGA cables to each monitor (as I have a multi-monitor system).
    Would this be better to avoid interference? as the DVI signal is digital, whilst VGA is analogue.
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Just the dvi signal is not converted into vga, it is just that the analog vga signals are transmported alongside the digital dvi signals that allows you to use a simple adaptor to change dvi to vga.
    Pinout:
    Pin 8 = Analog Vertical Sync
    C1 = Analog Red
    C2 = Analog Green
    C3 = Analog Blue
    C4 = Analog Horizontal Sync
    C5 = Analog Ground
    So now I am going to purchase a long shielded vga cable!
    Fox Mulder
    2004 Toyota MR2
    Low Bitrate joebagodoe's Avatar
    Oct 2004
    Kansas City, MO, USA
    Cold...Burrrrr
    It is getting closer to winter (21 deg Fahrenheit averages) and I had a question for those that have been through a winter with their carPC already. The components of the carPC will get very cold, so how do you let them warm up to operating temperature? Isn't it bad for them to pass through a due point temperature? Won’t the sweat start to merge circuits and cook things?
    Today I stuffed some dolls full of dead rats I put in the blender. I'm wondering if maybe, there really is something wrong with me.
  1. Laptop Display -> VGA + Power
    By Tabbe in forum LCD/Display
    Last Post: 07-25-2004, 04:21 PM
  2. What do you think of this VGA -> TV converter?
    By the_new_guy in forum LCD/Display
    Last Post: 06-24-2004, 09:32 PM
  3. vga -> composite -> vga (possible?)
    By Nav_Attack in forum LCD/Display
    Last Post: 04-03-2004, 12:38 PM
  4. Source for lond DVI & VGA cables.
    By TheSpecialist in forum LCD/Display
    Last Post: 02-23-2004, 11:34 PM
  5. composite -> vga
    By mp3z24 in forum LCD/Display
    Last Post: 03-26-2002, 10:56 AM
