Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Auto on not working in the cold
    Nov 2004
    Missouri
    Hello all...first post from a long time reader and lurker....
    I installed a pretty standard carputer over the summer...everything was happy until the recent cold weather spells here. See, I have a Lilliput, and like a lot of you I hacked it up and installed it in my dash with the auto on feature soldered in there (the capacitor and resistor)... My problem is the screen wont turn on if it sits overnight in the cold. When power is applied I can see a slight glow from the screen but the default green 'VGA' lettering and 'no video input' doesnt pop up. Now if i shut it off and turn it back on it will come up normally.
    Any help will be appreciated.... Tim...
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    Can't help you with a solution for the auto on, but I noticed that my Lilliput was very blurry Monday morning after sitting all weekend in the cold garage. I didn't notice this last winter, but I just shut the screen off and let the truck warm up for a few minutes and everything was fine.
    '03 Sierra Denali
    Jul 2004
    NL, Druten
    what the Fck is it with these screens..
    I seems to have a cold weather problem.
    When i turn on my pc the first 10 minutes are just noise on my screen. And after that it seems be work pretty fine.. Have to find out if it;s my screen or my vga card.
    sucks big time anyhow!!
    Maximum Bitrate knubile's Avatar
    If the screen works fine, and it's just the auto on that doesn't, it could be the temperature range for the resistor and capacitor used. They will definitely be affected by the change in temperature.
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Hey KingPlaza, how cold does it get there at the moment (celcius)? Then I'll check my xenarc for the same thing...
    Constant Bitrate snmnetwork's Avatar
    Aug 2004
    Atlanta, Ga
    Quote Originally Posted by scooby-rex
    I think i'm having the same problem. When the puter is turned on. The screen will come on, but with a white spash and faded out edges. Then it will start to show, but before that I end up turning it off then on with the remote then the screen would be normal again. Strange Sometimes I wish I never did this mod
    Status: [|||||||||-] 90% finished
    My 2000 Chevy Monte Carlo SS Install
    Aug 2004
    Atlanta, Ga
    Quote Originally Posted by knubile
    That sounds like it could be the problem. hmm
    Where is a good place to buy High Quality resistors and capacitors?
    Nov 2004
    Missouri
    Quote Originally Posted by snmnetwork
    Or perhaps a way to get some kind of relay in there to auto power on a few seconds after it receives power?... instead of powering on the moment the 12v hits it...
    Aug 2004
    Atlanta, Ga
    Yes, I beleive thats what my main problem is. Because a lot of things turn on at once, which may be causing the lilli to bug out. [Amp, ir reciever, gps reciever, and lilli
    It powers on flawless and fine from the house adapter, but the car is what gives me the problems. Before it got cold it would work fine the first time its turned on for the day, but if I shutdown then restart real qwik -like stop to get gas then restart the car, it would act up and show the symptoms. If i let it sit for an hour or 2 then start it back up it would come on fine. But now it acts up all the time.
    It's powered by my opus in the car.
    I'm new to the electronics thing, but can sloder pretty good. How can I build this sort of thing? I think it may be my amp causing the problems. I may have to put a relay on the remote wire going to the amp.? dunno?
    I'll run some tests with my amd diconnected and get back with some info.
    Nov 2004
    Missouri
    lilliput in the cold again
    Ok, after a flawless summer the temperature dipped below 50° and my screen doesnt turn on again. Anyone over the past year figure this one out? In the cold the auto on feature doenst work on the first try. I know it has got to do something with the capacitor and resistor in there. Any of you with a similar problem got a fix for this? thanks...
  1. Auto DJ function proposal.
    By kid320 in forum Media Engine
    Last Post: 07-26-2004, 06:35 PM
  2. Auto DJ function proposal... opinions?
    By kid320 in forum Software & Software Development
    Last Post: 07-26-2004, 11:07 AM
  3. itps auto power on not working
    By Noble in forum Power Supplies
    Last Post: 04-27-2004, 12:40 AM
  4. I remember some people working on a auto bartender
    By Scorpnstail in forum Off Topic
    Last Post: 03-05-2004, 08:13 PM
  5. motorized screen stopped working :(
    By corsamel in forum LCD/Display
    Last Post: 11-26-2002, 11:52 AM
