Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Want to test mobo with my laptop
    Dec 2003
    Talking Want to test mobo with my laptop
    Ok so Im trying to set-up my M1000. Its a pain in the *** for me to switch the monitor cable on my desktop to the M1000 when ever I need to transfer stuff. I know they make VGA cable splitters so I can switch over to the corresponding mobo. BUT i want to use my M1000 and the desktop at the same time.
    So is there a way to use my laptops LCD for the M1000.
    NOTE: This is a working laptop. This is not one of those redundant "i want to use a laptop LCD for my carputer" questions. or is it?
    Anyway, what do i have to do to set this up?
    ...please dont tell me to search, i already did. I kept getting threads on using ebay laptop LCDs controllers blah blah, however if you know a specific thread that has already addressed this issue post it up!
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Give up now. All the threads you've found are everything you're going to find. Without a controller board, you're SOL.
    Constant Bitrate sheerdark's Avatar
    Aug 2004
    Fayetteville, Ga - USA
    not unless your laptop came with a VGA in port.....and I doubt that it did.
    The only thing I can suggest is to invest in a KVM switch and hook that up to your desktop computer. That way, you can switch back and forth between your desktop and the carpc with a keystroke on your keyboard. If you only want to transfer files, this setup works just fine. A good 2 PC KVM should run you around 20-50...depends on where you get it. In the retail stores, I'm sure they're double that price. They make "all in one" units with cables (what I'm using now) and standalone units without cables (that I used to use). I got my all in one unit for around $30, but it was on sale...it's a belkin model. Great thing to have when working on computers!
    Good Luck,
    Matt
    Jan 2003
    Ruston, LA
    Vnc
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Aug 2004
    Quote Originally Posted by frodobaggins
    Vnc
    yeah, didn't even think about that.....PCAnywhere is my personal choice, but that's just because I own the program and am used to it. If you're using XP on both machines, it comes pre-installed with a program of this sort....can't remember for the life of me what it's called - I know I'll remember in a minute or two.
    Dec 2003
    how many computers can you hook up to a KVM switch?
    How stable are the remote networks when installing and running apps on the remote computer?
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Before I had another monitor for my carputer I used to use laplink over the parallel port (I found a laplink parallel cable), allows total control of the other computer. I used it to transfer files and install software just fine. However the parallel port can be a bit slow so don't go transferring a gig!
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    2, 4, 8, 16, 24.... as many as you want: Belkin is my personal choice. Unlike their cables, I have not had anything go wrong with my 8 portrack mounted KVM. http://www.belkin.com/config/Search/...D=1&search=kvm
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
    Aug 2004
    Quote Originally Posted by Tred
    The other person answered the KVM question well...I'll take on the other one. I have used VNC before and was not overly impressed, although I used PCAnywhere first, so I might have been biased. VNC is free and works well for what it was intended for, so you make your own choice.
    I love PCAnywhere because not only can you connect to the other pc and view its desktop and use it as if you were actually at the computer, no matter where that other computer is located, but you can also transfer files with it. I used to amaze my mother when I would connect to her computer from school to help her diagnose problems. Anyways, getting back on track... I have never had any problems running PCAnywhere while installing software or just playing around. I can transfer files from one machine to the other, to any directory on the machine from within the program window. It's really easy to setup, so long as you have a working network in place already.
    I use PCAnywhere 10.0, I believe, to control my file server that is stored on a shelf in the closet, as I do not have a keyboard, mouse, or monitor hooked up to it. It works great for my purposes. Good Luck!
    Matt
    Low Bitrate Wolfman's Avatar
    Nov 2003
    East Texas
    I use vnc to connect to my carputer from inside the house. I also use it when I have it inside for updates. Got tightvnc and never have any problems with it.
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 03:28 AM
  2. Need Desktop HD to laptop Mobo Connector
    By Joe_Collectible in forum General Hardware Discussion
    Last Post: 09-26-2004, 09:38 PM
  3. FS: Xbox, Dualie Mobo and Procs, Laptop
    By Shayughul in forum Classified Archive
    Last Post: 09-17-2004, 10:28 PM
  4. Laptop Mobo
    By EBFoxbat in forum General Hardware Discussion
    Last Post: 09-06-2004, 02:11 PM
  5. Replies: 11
    Last Post: 11-29-2003, 01:36 AM
