Results 1 to 3 of 3
Thread: LCD screen powered by MOSFET inverter
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    I wanted to post this for comments. I just installed my lillliput LCD screen in my WRX and to control the power, i used a mosfet inverter. The screen is powered by the battery which is always one, but the mosfet turns this power on when the ignition is on. I took the "Egg" apart too and included it in my circuit as well. Anyway, the mosfet turns the screen on very well and i was curious if anyone had any comments on if this is a good or bad way to power my screen? I currently haven't put an Opus powersupply or computer in, but I know that's another option to power my screen.
    thanks for any input!
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by warnockm
    I use the " egg" for the power of the Lilliput, and' ok, however' I have made 2 changes:
    1 - you put a filter on the entrance of the power EMI-RFI by MURATA name BNX002 (you make a searchin of Internet for datasheet) and so' you eliminate every trouble.
    2 - you put a relay in miniature, the spool you do h activate from the +12 of the MB, to the contact C you put the +12 Vbatt direct, and on the contact NA connects the power of the Lilliput.
    This way' and' the MB that " turns on" the Lilliput.
    Mauri
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    That sounds fine to me, mine is pretty much the same way I did it but I added a small circuit to delay the turn on of my lilliput by 15 secs so I dont get overrange coming out of hibernation
    肚子笑痛了
    S60 Install
  1. FS: M1023 Rev E controller + inverter + 10.4" screen
    By jusatry in forum Classified Archive
    Last Post: 05-12-2004, 03:09 PM
  2. touch screen for customized size lcd screen?
    By iPal in forum LCD/Display
    Last Post: 09-25-2003, 03:31 AM
  3. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
  4. Help on LCD screen
    By gunnt in forum LCD/Display
    Last Post: 06-17-2002, 03:18 PM
  5. Doubt before buying an power acoustik lcd screen
    By cyrofilho in forum LCD/Display
    Last Post: 06-01-2002, 10:40 PM
