Results 1 to 5 of 5
Thread: Need Xenarc internal cable help!!
    Apr 2001
    NJ, USA
    Need Xenarc w/touchscreen internal cable help!!
    I took apart my Xenon to replace the internal fuse. Now I've got a problem with connectors. The screen is almost 1 year old, has the t/s and vga.
    Can someone please verify where the 4-conductor cable goes from the white 4-pin connector where the vga connector is....where does the other end go? I can't remember. I thought it goes to the white connector on the little touchscreen/USB card, but that's got 5 pins. I don't think I misplaced the cable but the cable I have is 4pin to 4pin. The cable will fit into this connector but it's going to be off by one pin. Can someone either confirm of maybe have a pic already of their Xenarc's w/touch board? Thanks!
    P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    Quote Originally Posted by Tony S
    Can someone please verify where the 4-conductor cable goes from the white 4-pin connector where the vga connector is....where does the other end go? I can't remember. I thought it goes to the white connector on the touchscreen/USB card that sits on top of the big cpu, but that's got 5 pins.
    I don't think I misplaced the cable but the cable I have is 4pin to 4pin. The cable will fit into this connector but it's going to be off by one pin. Can someone either confirm of maybe have a pic already of their Xenarc's board? Thanks!
    Check digitalww site. I remember seeing photo of Xenarc module.
    I will look for link later.
    Apr 2001
    NJ, USA
    Will do. Thanks.
    Apr 2001
    NJ, USA
    This appears to be the same touch module I have in the Xenarc:
    http://www.digitalww.com/images/controler_front.jpg
    HAA!! I JUST FOUND THE PIC I NEEDED! http://www.digitalww.com/images/VGAM_assembeled3.JPG shows that the connector, which IS the 4-conductor cable, goes into the 4 right-most pins on the touch card's connector! Yeah baby! I didn't think of digitalww. Thanks for pointing me there, bro!
    Nov 2003
    TN
    No problem.
  1. Does Xenarc use a DFP to VGA cable?
    By Player_One in forum LCD/Display
    Last Post: 11-08-2004, 04:27 AM
  2. Xenarc 700y Vga Cable
    By pinox in forum LCD/Display
    Last Post: 10-12-2004, 03:53 AM
  3. Laptop Internal Connector Cable??
    By amessana in forum General Hardware Discussion
    Last Post: 10-01-2004, 03:45 PM
  4. Xenarc 700TSV cable broken.
    By ripper in forum Input Devices
    Last Post: 04-25-2004, 06:03 AM
  5. Xenarc AC/DC cable
    By Sunglassesron in forum LCD/Display
    Last Post: 10-02-2003, 04:15 AM
